Up to 20% off select tools
OnePlus 6T Back Cover Replacement
Views: 22K
View statistics:
Past 24 Hours:
10
Past 7 Days:
35
Past 30 Days:
179
All Time:
21,796
Comments: 11
5 comments on steps, 6 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your OnePlus 6T back cover is damaged or scratched, or you need to access the internal components of your phone, follow this simple guide to remove the back cover.
Before you begin, make sure that your phone is powered off and unplugged from the charger.
    1. OnePlus 6T Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
      Ask FixBot
    2. OnePlus 6T Back Cover Replacement: step 2, image 1 of 1
      • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
      • Carefully remove the SIM card from its tray.
      Ask FixBot
    3. OnePlus 6T Back Cover Replacement: step 3, image 1 of 1
      • Loosen the binding glue within the phone using a hairdryer or an iOpener.
      • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
      Ask FixBot
    4. OnePlus 6T Back Cover Replacement: step 4, image 1 of 3 OnePlus 6T Back Cover Replacement: step 4, image 2 of 3 OnePlus 6T Back Cover Replacement: step 4, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
      • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
      • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
      • Remove the back cover from the phone.
      • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
      Ask FixBot
19 other people completed this guide.
Author
with
Kira D'Agostino
1,775 Reputation
2 Guides authored
6 Guide Comments
I wonder if this is the same for OnePlus 6 (6000/6003)?
karlkristians - Reply Share
another greath guide, repaird check.
In same time rplacd the battery so phone is ready for another few years
yoeri - Reply Share
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Alexandre Herbreteau - Reply Share
Preciso de uma tela para o one plus 6t
Fred Silva - Reply Share
Tela one plus 6t quem sabe onde ou se alguém vende
Past 24 Hours: 10
Past 7 Days: 35
Past 30 Days: 179
All Time: 21,796
