Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓If your OnePlus 6 isn’t responding to the commands of the power buttons when you press them, use this guide to replace the power buttons.
When pressed, the power buttons relay messages to the motherboard to start up the device or to control the volume of the speakers. Broken or faulty power buttons won’t transmit these signals to the motherboard causing the phone not to respond to the commands.
Before using this replacement guide, make sure that no debris is lodged between the buttons and the phone as it will prohibit the signals from the buttons to be observed. Loose connectors to the power buttons can also result in disruption of the relays sent to the motherboard. Be sure to check out the troubleshooting page to see if a solution can be found without a replacement.
The first step in this replacement process is to remove the back panel of the phone, which is made out of glass. Make sure to be careful removing it that you do not shatter it.
Make sure to turn the device off and to unplug any outside power sources before starting the replacement.
Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
Repeat until the back panel is fully released.
Grip the green tab connected to the battery and pull the battery directly up and out.
Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
Lift the bottom of the mid frame directly up and remove it from the device.
Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
4 other people completed this guide.
