Up to 20% off select tools
OnePlus 6 Rear Camera Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
118
All Time:
2,076
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 40 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
If the back camera is not working on your OnePlus 6, use this guide to replace the broken camera.
The rear-facing camera allows you to take pictures and videos from the back of the phone and send them into the phone’s memory. A broken or disconnected camera will not permit you to so.
The back camera not being available for use may be from the camera lens being cracked, the connector to the camera being disconnected or loose, or the phone is simply using the camera in another app.
Before deciding to replace the camera in your OnePlus 6, inspect the lenses for any cracks as the phone will show a distorted image as a result or no image due to hardware damage. Make sure to check out the troubleshooting page for this device to see if you can fix this problem without a replacement. If nothing seems to be working for you, we’ve got you covered on how to replace your broken camera with a new one in this replacement guide to get you back to snapping some photos at ease.
The first step of this replacement guide is to remove the back panel of the phone. The back panel is made out of glass, so be careful when removing not to shatter it.
Before performing this replacement, back up your phone to prevent any loss of photos or videos. Also, take the time to ensure that the phone is powered off and disconnected from outside sources before continuing.
    1. OnePlus 6 Rear Camera Replacement, Back Panel: step 1, image 1 of 1
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      Ask FixBot
    2. OnePlus 6 Rear Camera Replacement: step 2, image 1 of 2 OnePlus 6 Rear Camera Replacement: step 2, image 2 of 2
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      Ask FixBot
    3. OnePlus 6 Rear Camera Replacement: step 3, image 1 of 2 OnePlus 6 Rear Camera Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      Ask FixBot
    1. OnePlus 6 Rear Camera Replacement, Battery: step 4, image 1 of 2 OnePlus 6 Rear Camera Replacement, Battery: step 4, image 2 of 2
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      Ask FixBot
    1. OnePlus 6 Rear Camera Replacement, Fingerprint sensor: step 5, image 1 of 2 OnePlus 6 Rear Camera Replacement, Fingerprint sensor: step 5, image 2 of 2
      • The midframe is made of plastic and located above the battery space.
      • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
      • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
      • Lift the bottom of the mid frame directly up and remove it from the device.
      Ask FixBot
    1. OnePlus 6 Rear Camera Replacement, Motherboard: step 6, image 1 of 1
      • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    2. OnePlus 6 Rear Camera Replacement: step 7, image 1 of 2 OnePlus 6 Rear Camera Replacement: step 7, image 2 of 2
      • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
      • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
      • The cameras should lift up with the motherboard.
      Ask FixBot
    1. OnePlus 6 Rear Camera Replacement, Rear Camera: step 8, image 1 of 2 OnePlus 6 Rear Camera Replacement, Rear Camera: step 8, image 2 of 2
      • Lift up on the small tabs connecting the cameras to the motherboard to disconnect them.
      • Push on the lens side of the cameras and remove them from the motherboard.
      Ask FixBot
Author
with
Hunter Brown
118 Reputation
1 Guide authored
Clemson, Team 4-3, Hunter Fall 2021 Member of Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 118
All Time: 2,076
