Up to 20% off select tools
OnePlus 6 Charging Port Replacement
Views: 8.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
150
All Time:
8,406
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If your OnePlus 6 isn't charging when plugged into a charging cable, the charging port may be broken and will need to be replaced. The charger port transmits power to the battery and without a reliable charger port, the phone will not have any power to run.
Always test the phone using cables that you know work to ensure that the charging cable itself isn’t the issue. Also, consider that the battery may be faulty. Poor charging can be caused by many things so be sure to check out the OnePlus 6 Troubleshooting page before completing this replacement guide.
The first step in this guide requires the removal of the back panel of the phone, which is usually made of glass so be careful not to shatter it.
Before completing this guide make sure that the phone is powered off and that there are no power sources connected to it.
    1. OnePlus 6 Charging Port Replacement, Back Panel: step 1, image 1 of 1
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      Ask FixBot
    2. OnePlus 6 Charging Port Replacement: step 2, image 1 of 2 OnePlus 6 Charging Port Replacement: step 2, image 2 of 2
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      Ask FixBot
    3. OnePlus 6 Charging Port Replacement: step 3, image 1 of 2 OnePlus 6 Charging Port Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      Ask FixBot
    1. OnePlus 6 Charging Port Replacement, Battery: step 4, image 1 of 2 OnePlus 6 Charging Port Replacement, Battery: step 4, image 2 of 2
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      Ask FixBot
    1. OnePlus 6 Charging Port Replacement, Lower Frame: step 5, image 1 of 2 OnePlus 6 Charging Port Replacement, Lower Frame: step 5, image 2 of 2
      • Using the Phillips #00 screwdriver, remove the eight 3 mm screws from the lower frame.
      • Gently lift the lower panel up and out of the device.
      Ask FixBot
    1. OnePlus 6 Charging Port Replacement, Charging Port: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the two 2.3 mm screws with the screwdriver located on the two ends of the charging port.
      Ask FixBot
    2. OnePlus 6 Charging Port Replacement: step 7, image 1 of 1
      Buy
      • Gently disconnect the four connectors surrounding the charging port using a pair of tweezers.
      Ask FixBot
    3. OnePlus 6 Charging Port Replacement: step 8, image 1 of 1
      • Pull the rubber strip up with your finger located just inside of the battery housing.
      Ask FixBot
    4. OnePlus 6 Charging Port Replacement: step 9, image 1 of 1
      • Using the tweezers, grab the charging port ribbon cable and pull it towards the top of the phone.
      • Gently remove the charging port and its cable from the device.
      Ask FixBot
6 other people completed this guide.
Author
with
John Steven Trammell
961 Reputation
4 Guides authored
Clemson, Team 4-3, Hunter Fall 2021 Member of Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Members
96 Guides authored
1 Guide Comment
Helpful guide! However, there are some steps missing. Between step 7 and 9, the daughter board needs to be lifted up to make room to remove the charging port. It doesn't have to be fully removed, and it is held in place with some adhesive. Also, the charging port connects to the main-board, and that is held down by a plastic shield. Some screws will need to be removed. Once the plastic shield is removed, the charging port can be unplugged from the main-board and fully removed.
Menelik Seth - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 150
All Time: 8,406
