OnePlus 5T Speaker Replacement
    1. OnePlus 5T Speaker Replacement, Back Cover: step 1, image 1 of 2 OnePlus 5T Speaker Replacement, Back Cover: step 1, image 2 of 2
      • Before you begin, switch off your phone.
      • Remove the SIM card tray.
      Ask FixBot
    2. OnePlus 5T Speaker Replacement: step 2, image 1 of 1
      • Remove the two Torx T2 screws (2.5 mm length).
      • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
      Ask FixBot
    3. OnePlus 5T Speaker Replacement: step 3, image 1 of 3 OnePlus 5T Speaker Replacement: step 3, image 2 of 3 OnePlus 5T Speaker Replacement: step 3, image 3 of 3
      • Insert an opening tool between the display and the backcover at the bottom end of the phone.
      • Use the opening tool to create a gap between back cover and display.
      • Insert an opening pick in the gap you created with the opening tool.
      Ask FixBot
    4. OnePlus 5T Speaker Replacement: step 4, image 1 of 3 OnePlus 5T Speaker Replacement: step 4, image 2 of 3 OnePlus 5T Speaker Replacement: step 4, image 3 of 3
      • Slide the opening pick to the bottom right corner of the phone.
      • Insert a second opening pick and slide it to the bottom left corner of the phone.
      Ask FixBot
    5. OnePlus 5T Speaker Replacement: step 5, image 1 of 3 OnePlus 5T Speaker Replacement: step 5, image 2 of 3 OnePlus 5T Speaker Replacement: step 5, image 3 of 3
      • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
      Ask FixBot
    6. OnePlus 5T Speaker Replacement: step 6, image 1 of 3 OnePlus 5T Speaker Replacement: step 6, image 2 of 3 OnePlus 5T Speaker Replacement: step 6, image 3 of 3
      • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
      Ask FixBot
    7. OnePlus 5T Speaker Replacement: step 7, image 1 of 3 OnePlus 5T Speaker Replacement: step 7, image 2 of 3 OnePlus 5T Speaker Replacement: step 7, image 3 of 3
      • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
      • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
      Ask FixBot
    8. OnePlus 5T Speaker Replacement: step 8, image 1 of 2 OnePlus 5T Speaker Replacement: step 8, image 2 of 2
      • Use a spudger to pry up and disconnect the fingerprint flex cable.
      Ask FixBot
    9. OnePlus 5T Speaker Replacement: step 9, image 1 of 3 OnePlus 5T Speaker Replacement: step 9, image 2 of 3 OnePlus 5T Speaker Replacement: step 9, image 3 of 3
      • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
      Ask FixBot
    10. OnePlus 5T Speaker Replacement: step 10, image 1 of 3 OnePlus 5T Speaker Replacement: step 10, image 2 of 3 OnePlus 5T Speaker Replacement: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
      Ask FixBot
    11. OnePlus 5T Speaker Replacement: step 11, image 1 of 2 OnePlus 5T Speaker Replacement: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
      Ask FixBot
    12. OnePlus 5T Speaker Replacement: step 12, image 1 of 2 OnePlus 5T Speaker Replacement: step 12, image 2 of 2
      • Remove the backcover.
      Ask FixBot
    1. OnePlus 5T Speaker Replacement, Battery Disconnect: step 13, image 1 of 2 OnePlus 5T Speaker Replacement, Battery Disconnect: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    1. OnePlus 5T Speaker Replacement, Speaker: step 14, image 1 of 1
      • Remove the six Phillips #00 screws (2.9 mm length).
      Ask FixBot
    2. OnePlus 5T Speaker Replacement: step 15, image 1 of 3 OnePlus 5T Speaker Replacement: step 15, image 2 of 3 OnePlus 5T Speaker Replacement: step 15, image 3 of 3
      • Slide an opening pick underneath the left side of the speaker.
      • Use the opening pick to pry the speaker up and out of its recess.
      Ask FixBot
    3. OnePlus 5T Speaker Replacement: step 16, image 1 of 2 OnePlus 5T Speaker Replacement: step 16, image 2 of 2
      • Remove the speaker.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
5 other people completed this guide.
Dominik Schnabelrauch
266,047 Reputation
682 Guides authored
2 Guide Comments
Following water damage the loudspeaker stopped working. I changed it out (twice) and the flex cable but still not working. Any ideas?
Daryl - Reply Share
did you ever find a solution to this issue?
Neil Kumaran - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 61
All Time: 3,359
