Up to 20% off select tools
OnePlus 5 Loudspeaker Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
94
All Time:
2,982
Comments: 18
18 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Follow this guide to remove the loudspeaker assembly from a OnePlus 5. The hardest part is getting the frame clips free. Once that is done, the speaker assembly comes out easily.
    1. OnePlus 5 Loudspeaker Replacement, SIM Card Tray: step 1, image 1 of 3 OnePlus 5 Loudspeaker Replacement, SIM Card Tray: step 1, image 2 of 3 OnePlus 5 Loudspeaker Replacement, SIM Card Tray: step 1, image 3 of 3
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
      • Press firmly to eject the tray.
      • During reassembly, be sure to properly orient the SIM tray you you insert it.
      Ask FixBot
    1. OnePlus 5 Loudspeaker Replacement, Back Cover: step 2, image 1 of 1
      • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
      Ask FixBot
    2. OnePlus 5 Loudspeaker Replacement: step 3, image 1 of 3 OnePlus 5 Loudspeaker Replacement: step 3, image 2 of 3 OnePlus 5 Loudspeaker Replacement: step 3, image 3 of 3
      • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
      • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
      • There are two different seams between the body and the screen of the phone:
      • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
      • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
      • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
      Ask FixBot
    3. OnePlus 5 Loudspeaker Replacement: step 4, image 1 of 2 OnePlus 5 Loudspeaker Replacement: step 4, image 2 of 2
      • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
      • Place a suction cup near the bottom edge of the display.
      • Pull on the suction cup with strong steady force.
      • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
      • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
      Ask FixBot
    4. OnePlus 5 Loudspeaker Replacement: step 5, image 1 of 3 OnePlus 5 Loudspeaker Replacement: step 5, image 2 of 3 OnePlus 5 Loudspeaker Replacement: step 5, image 3 of 3
      • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
      • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
      Ask FixBot
    5. OnePlus 5 Loudspeaker Replacement: step 6, image 1 of 2 OnePlus 5 Loudspeaker Replacement: step 6, image 2 of 2
      • Lever the opening tool to release the first clip from the frame.
      Ask FixBot
    6. OnePlus 5 Loudspeaker Replacement: step 7, image 1 of 3 OnePlus 5 Loudspeaker Replacement: step 7, image 2 of 3 OnePlus 5 Loudspeaker Replacement: step 7, image 3 of 3
      • Continue sliding the opening tool along the long edge, releasing the clips along the way.
      • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
      Ask FixBot
    7. OnePlus 5 Loudspeaker Replacement: step 8, image 1 of 1
      • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
      • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
      • During reassembly, pause here to test your phone's functionality before securing the back cover.
      • To reinstall the back cover:
      • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
      • Squeeze along the long edges of the phone to snap the remaining clips into place.
      Ask FixBot
    8. OnePlus 5 Loudspeaker Replacement: step 9, image 1 of 3 OnePlus 5 Loudspeaker Replacement: step 9, image 2 of 3 OnePlus 5 Loudspeaker Replacement: step 9, image 3 of 3
      • With all the clips released, flip the phone over so that the display is face-down.
      • Swing the back cover around and rest it on top of the exposed frame.
      • Be careful not to stress the flex cable connecting the back cover and the frame.
      Ask FixBot
    9. OnePlus 5 Loudspeaker Replacement: step 10, image 1 of 2 OnePlus 5 Loudspeaker Replacement: step 10, image 2 of 2
      • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
      • Lift up and remove the cable bracket.
      • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
      Ask FixBot
    10. OnePlus 5 Loudspeaker Replacement: step 11, image 1 of 2 OnePlus 5 Loudspeaker Replacement: step 11, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    11. OnePlus 5 Loudspeaker Replacement: step 12, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. OnePlus 5 Loudspeaker Replacement, Loudspeaker: step 13, image 1 of 1
      • Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
      Ask FixBot
    2. OnePlus 5 Loudspeaker Replacement: step 14, image 1 of 2 OnePlus 5 Loudspeaker Replacement: step 14, image 2 of 2
      • Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
      Ask FixBot
    3. OnePlus 5 Loudspeaker Replacement: step 15, image 1 of 1
      • Remove the loudspeaker.
      • To reinstall the loudspeaker, align the loudspeaker's bottom edge to the frame, then press the assembly into place.
      • During reinstallation, make sure that the display cable connector under the loudspeaker assembly is still securely fastened.
      Ask FixBot
Repair didn’t go as planned? Check out our OnePlus 5 Answers community for troubleshooting help.
Author
with
Arthur Shi
354,406 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 94
All Time: 2,982
