Up to 20% off select tools
OnePlus 2 Battery Replacement
Views: 55K
View statistics:
Past 24 Hours:
9
Past 7 Days:
32
Past 30 Days:
129
All Time:
55,383
Comments: 25
4 comments on steps, 21 guide comments.
Go to guide comments
Completed: 99
99 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
If you have have noticed your phone charge dying rapidly or inconsistently, perhaps it's time to replace your battery. This guide will show you how to do that.
    1. OnePlus 2 Battery Replacement, SIM Card: step 1, image 1 of 3 OnePlus 2 Battery Replacement, SIM Card: step 1, image 2 of 3 OnePlus 2 Battery Replacement, SIM Card: step 1, image 3 of 3
      • Make sure that your phone is turned off before proceeding
      • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
      Ask FixBot
    2. OnePlus 2 Battery Replacement: step 2, image 1 of 3 OnePlus 2 Battery Replacement: step 2, image 2 of 3 OnePlus 2 Battery Replacement: step 2, image 3 of 3
      • Locate the SIM card tray on the back of the phone
      • Use your thumb to gently slide out the tray
      Ask FixBot
    3. OnePlus 2 Battery Replacement: step 3, image 1 of 1
      • Remove the SIM card tray
      Ask FixBot
    1. OnePlus 2 Battery Replacement, Battery: step 4, image 1 of 3 OnePlus 2 Battery Replacement, Battery: step 4, image 2 of 3 OnePlus 2 Battery Replacement, Battery: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Find and carefully remove all 6 rubber screw covers with the tweezers.
      • Unscrew all 18 screws from the mid frame.
      Ask FixBot
    2. OnePlus 2 Battery Replacement: step 5, image 1 of 3 OnePlus 2 Battery Replacement: step 5, image 2 of 3 OnePlus 2 Battery Replacement: step 5, image 3 of 3
      • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
      • Slowly work your way around the phone releasing all the clips that hold the frame in place.
      Ask FixBot
    3. OnePlus 2 Battery Replacement: step 6, image 1 of 3 OnePlus 2 Battery Replacement: step 6, image 2 of 3 OnePlus 2 Battery Replacement: step 6, image 3 of 3
      • Using the spudger tool, pry the battery up from the adhesive.
      • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
      Ask FixBot
99 other people completed this guide.
Author
with
Kayla Williams
1,544 Reputation
6 Guides authored
Cal Poly, Team 4-5, Maness Fall 2015 Member of Cal Poly, Team 4-5, Maness Fall 2015
CPSU-MANESS-F15S4G5
4 Members
72 Guides authored
21 Guide Comments
Nice to see that, thanx !
But do you know where it's possible to buy a new battery ?
I see "designed by oneplus" on it and I'm not sure it would be easy to find one on internet usual stores.
Fred Hamel - Reply Share
You can look up a oneplus service center in your country/locality by going to your country's version of the oneplus site. There in the support -->Contact Us, you will find a list of places(service centers) you can go for repairs and a price list of all the parts and the service to replace them. Not sure if this works for every country, worked for me.
Zuke Denvar - Reply Share
this is not a full help.. how do we suppose to buy official battery for onelus2?
and this method would be great if you upload a video in full detail without missing any point.
so, please do that. Thanks in advance!
shahfaishalkhan - Reply Share
Use google.com and search for BLP597 that's the itemnumber of the battery in question. There are plenty of sellers available.
Markus Flaig - Reply Share
any good battery for oneplus 2? i wanna buy a new battery for oneplus 2 can you please suggest me good battery for it? please tell me i really need it asap.
Thank you!!
Aalok Kumar - Reply Share
Past 24 Hours: 9
Past 7 Days: 32
Past 30 Days: 129
All Time: 55,383
