Up to 20% off select tools
OneLink Safe and Sound Microphone Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
69
All Time:
628
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to replace the microphone of your OneLink Safe and Sound smoke and carbon monoxide alarm and premium home speaker with Alexa, follow this guide.
If the microphone is not working, the Alexa feature will not work. For help with troubleshooting your device, visit the OneLink Safe and Sound Troubleshooting page.
    1. OneLink Safe and Sound Microphone Replacement, Cover: step 1, image 1 of 2 OneLink Safe and Sound Microphone Replacement, Cover: step 1, image 2 of 2
      • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
      • Remove plastic rim.
      Ask FixBot
    2. OneLink Safe and Sound Microphone Replacement: step 2, image 1 of 2 OneLink Safe and Sound Microphone Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
      Ask FixBot
    3. OneLink Safe and Sound Microphone Replacement: step 3, image 1 of 2 OneLink Safe and Sound Microphone Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
      • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
      Ask FixBot
    4. OneLink Safe and Sound Microphone Replacement: step 4, image 1 of 1
      • Use tweezers to unplug the speaker cable from the motherboard.
      Ask FixBot
    5. OneLink Safe and Sound Microphone Replacement: step 5, image 1 of 2 OneLink Safe and Sound Microphone Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to remove the microphone connection from the motherboard.
      • Remove the top of the device.
      Ask FixBot
    1. OneLink Safe and Sound Microphone Replacement, Microphone: step 6, image 1 of 2 OneLink Safe and Sound Microphone Replacement, Microphone: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two screws that secure the microphone to the device.
      Ask FixBot
    2. OneLink Safe and Sound Microphone Replacement: step 7, image 1 of 1
      • Use your hands to remove the microphone.
      Ask FixBot
Author
with
Arianna Roberts
687 Reputation
6 Guides authored
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 69
All Time: 628
