Up to 20% off select tools
OneLink Safe and Sound Bluetooth Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
73
All Time:
689
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your OneLink Safe and Sound won't connect to your phone via Bluetooth it could be due to a malfunctioning Bluetooth module. This guide will walk you through opening the device and removing/replacing the Bluetooth module. The only knowledge needed is identifying the different cables used to connect the top half to the bottom half. Before replacing the Bluetooth module, please refer to the OneLink Safe and Sound Troubleshooting page for other fixes to this problem. Also before removing the OneLink from the ceiling, make sure to turn off power at your building's junction box. With the right tools you can expect to completely replace the Bluetooth module and restore it to working order.
    1. OneLink Safe and Sound Bluetooth Module Replacement, Cover: step 1, image 1 of 2 OneLink Safe and Sound Bluetooth Module Replacement, Cover: step 1, image 2 of 2
      • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
      • Remove plastic rim.
      Ask FixBot
    2. OneLink Safe and Sound Bluetooth Module Replacement: step 2, image 1 of 2 OneLink Safe and Sound Bluetooth Module Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
      Ask FixBot
    3. OneLink Safe and Sound Bluetooth Module Replacement: step 3, image 1 of 2 OneLink Safe and Sound Bluetooth Module Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
      • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
      Ask FixBot
    4. OneLink Safe and Sound Bluetooth Module Replacement: step 4, image 1 of 1
      • Use tweezers to unplug the speaker cable from the motherboard.
      Ask FixBot
    5. OneLink Safe and Sound Bluetooth Module Replacement: step 5, image 1 of 2 OneLink Safe and Sound Bluetooth Module Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to remove the microphone connection from the motherboard.
      • Remove the top of the device.
      Ask FixBot
    1. OneLink Safe and Sound Bluetooth Module Replacement, Bluetooth Module: step 6, image 1 of 1
      • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
      Ask FixBot
    2. OneLink Safe and Sound Bluetooth Module Replacement: step 7, image 1 of 2 OneLink Safe and Sound Bluetooth Module Replacement: step 7, image 2 of 2
      • Lift the Bluetooth module off of the daughterboard.
      • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
      Ask FixBot
Author
with
Arianna Roberts
687 Reputation
6 Guides authored
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 73
All Time: 689
