Up to 20% off select tools
OneLink Safe and Sound Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
102
All Time:
3,988
Comments: 11
5 comments on steps, 6 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The battery is the backup to the device's hardwired design and is meant to last ten years. However, if the battery fails, follow this guide to replace the battery of your OneLink Safe and Sound. It's important to have the battery installed and working in case of a power outage and the hardwire is inoperable.
    1. OneLink Safe and Sound Battery Replacement, Cover: step 1, image 1 of 2 OneLink Safe and Sound Battery Replacement, Cover: step 1, image 2 of 2
      • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
      • Remove plastic rim.
      Ask FixBot
    2. OneLink Safe and Sound Battery Replacement: step 2, image 1 of 2 OneLink Safe and Sound Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
      Ask FixBot
    3. OneLink Safe and Sound Battery Replacement: step 3, image 1 of 2 OneLink Safe and Sound Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
      • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
      Ask FixBot
    4. OneLink Safe and Sound Battery Replacement: step 4, image 1 of 1
      • Use tweezers to unplug the speaker cable from the motherboard.
      Ask FixBot
    5. OneLink Safe and Sound Battery Replacement: step 5, image 1 of 2 OneLink Safe and Sound Battery Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to remove the microphone connection from the motherboard.
      • Remove the top of the device.
      Ask FixBot
    1. OneLink Safe and Sound Battery Replacement, Battery: step 6, image 1 of 1
      • Use the plastic opening tool to disconnect the cable from the motherboard.
      Ask FixBot
    2. OneLink Safe and Sound Battery Replacement: step 7, image 1 of 2 OneLink Safe and Sound Battery Replacement: step 7, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
      Ask FixBot
    3. OneLink Safe and Sound Battery Replacement: step 8, image 1 of 2 OneLink Safe and Sound Battery Replacement: step 8, image 2 of 2
      • Remove the plastic cage holding the battery in place.
      • Remove the battery from the device.
      Ask FixBot
3 other people completed this guide.
Author
with
Arianna Roberts
687 Reputation
6 Guides authored
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Members
72 Guides authored
6 Guide Comments
Where do I get this battery replacement
Dallas Massey - Reply Share
people that has purchased this product. If the battery goes dead where can someone purchase a replacement battery from and what size battery would they need
Pamela Wright - Reply Share
@pamelawrig63185 They don’t sell replacement battery anymore. so I had to make them using my spot welder. contact your local repair shop for it.
iFIX smartphone - Reply Share
Is there a P/N for the battery pack or it needs to be bought individually and then put together
Thank you
Jose Chocano Felice - Reply Share
Bought a 2CR17335A-WK17 battery pack from Amazon for $15 plus tax. Just had to splice wires to existing connector to match the motherboard. So far so good. Had a 5 chirp tone every 2 minutes advising battery had come to end of life. Not sure why a 10 year battery only lasted 3 years from the manufacturing date but oh well.
Mario Garcia - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 102
All Time: 3,988
