Up to 20% off select tools
One Education Infinity:One Camera Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
82
All Time:
822
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In the One Education Infinity:One laptop, the front and rear facing cameras are one component. If you are experiencing performance issues with either camera this guide will help you replace them.
    1. One Education Infinity:One Camera Assembly Replacement, Battery: step 1, image 1 of 2 One Education Infinity:One Camera Assembly Replacement, Battery: step 1, image 2 of 2
      • Use a spudger to disconnect the black bundled cable connector from the motherboard.
      Ask FixBot
    2. One Education Infinity:One Camera Assembly Replacement: step 2, image 1 of 3 One Education Infinity:One Camera Assembly Replacement: step 2, image 2 of 3 One Education Infinity:One Camera Assembly Replacement: step 2, image 3 of 3
      • Use a spudger to lift the black tab on top of the ZIF connector.
      • Slide the ribbon cable out of the connector.
      Ask FixBot
    3. One Education Infinity:One Camera Assembly Replacement: step 3, image 1 of 3 One Education Infinity:One Camera Assembly Replacement: step 3, image 2 of 3 One Education Infinity:One Camera Assembly Replacement: step 3, image 3 of 3
      • Use a spudger to flip up the black retaining flap on the ZIF connector.
      • Pull the folded ribbon cable straight out of the connector.
      • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
      Ask FixBot
    4. One Education Infinity:One Camera Assembly Replacement: step 4, image 1 of 1
      • Use a spudger to pry the battery away from the device.
      • Always use ESD safe tools when working with delicate electrical components.
      Ask FixBot
    1. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: step 5, image 1 of 3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: step 5, image 2 of 3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: step 5, image 3 of 3
      • Use a spudger to flip up the black flap on the camera's ZIF connector.
      • Pull the ribbon cable straight out of the connector.
      Ask FixBot
    2. One Education Infinity:One Camera Assembly Replacement: step 6, image 1 of 2 One Education Infinity:One Camera Assembly Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the black cushion surrounding the camera lens.
      Ask FixBot
    3. One Education Infinity:One Camera Assembly Replacement: step 7, image 1 of 2 One Education Infinity:One Camera Assembly Replacement: step 7, image 2 of 2
      • Use tweezers to lift the camera assembly away from the device.
      • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
      Ask FixBot
Author
with
Taylor Bratsch
6,203 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 82
All Time: 822
