Up to 20% off select tools
One Education Infinity:One Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
79
All Time:
1,627
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will detail how to safely remove the battery from the One Education Infinity:One laptop.
    1. One Education Infinity:One Battery Replacement, Top Case: step 1, image 1 of 3 One Education Infinity:One Battery Replacement, Top Case: step 1, image 2 of 3 One Education Infinity:One Battery Replacement, Top Case: step 1, image 3 of 3
      • Insert a Jimmy or other prying tool into the seam between the screen and back case.
      • Trace around the edges until all clips are released.
      • Lift the back case away from the tablet.
      Ask FixBot
    1. One Education Infinity:One Battery Replacement, Battery: step 2, image 1 of 2 One Education Infinity:One Battery Replacement, Battery: step 2, image 2 of 2
      • Use a spudger to disconnect the black bundled cable connector from the motherboard.
      Ask FixBot
    2. One Education Infinity:One Battery Replacement: step 3, image 1 of 3 One Education Infinity:One Battery Replacement: step 3, image 2 of 3 One Education Infinity:One Battery Replacement: step 3, image 3 of 3
      • Use a spudger to lift the black tab on top of the ZIF connector.
      • Slide the ribbon cable out of the connector.
      Ask FixBot
    3. One Education Infinity:One Battery Replacement: step 4, image 1 of 3 One Education Infinity:One Battery Replacement: step 4, image 2 of 3 One Education Infinity:One Battery Replacement: step 4, image 3 of 3
      • Use a spudger to flip up the black retaining flap on the ZIF connector.
      • Pull the folded ribbon cable straight out of the connector.
      • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
      Ask FixBot
    4. One Education Infinity:One Battery Replacement: step 5, image 1 of 1
      • Use a spudger to pry the battery away from the device.
      • Always use ESD safe tools when working with delicate electrical components.
      Ask FixBot
Author
with
Taylor Bratsch
6,203 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 79
All Time: 1,627
