Up to 20% off select tools
One Education Infinity Webcam Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
57
All Time:
460
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide details the process of removing and replacing a malfunctioning webcam in the One Education Infinity.
The webcam of the One Education Infinity is the sole photo-capturer of the device, and is mounted on a swivel, which allows it to function both as a front facing camera in laptop mode as well as a back facing camera in tablet mode (although it does sit at a slight angle to account for the bottom case).
If the webcam is malfunctioning, it should be fairly obvious. Simply open any app that utilizes the camera and check that the picture shows up clearly. If the camera lens has been cleaned and any software issues ruled out, then the issue is with the physical camera component, and it should be replaced.
Additionally, note that this guide has the user remove the battery prior to disassembling the upper case to prevent any electrical damage while disconnecting the display cables. However, the same effect can be achieved by simply disconnecting the battery cable, so the battery removal in step 5 can be skipped to save a bit of time and effort.
    1. One Education Infinity Webcam Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Webcam Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Webcam Replacement, Back Case: step 1, image 3 of 3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      Ask FixBot
    2. One Education Infinity Webcam Replacement: step 2, image 1 of 2 One Education Infinity Webcam Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      Ask FixBot
    3. One Education Infinity Webcam Replacement: step 3, image 1 of 3 One Education Infinity Webcam Replacement: step 3, image 2 of 3 One Education Infinity Webcam Replacement: step 3, image 3 of 3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      Ask FixBot
    1. One Education Infinity Webcam Replacement, Battery: step 4, image 1 of 3 One Education Infinity Webcam Replacement, Battery: step 4, image 2 of 3 One Education Infinity Webcam Replacement, Battery: step 4, image 3 of 3
      • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
      • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
      Ask FixBot
    2. One Education Infinity Webcam Replacement: step 5, image 1 of 3 One Education Infinity Webcam Replacement: step 5, image 2 of 3 One Education Infinity Webcam Replacement: step 5, image 3 of 3
      • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
      • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
      • Lift the battery out from the internal case.
      Ask FixBot
    1. One Education Infinity Webcam Replacement, Upper Case: step 6, image 1 of 3 One Education Infinity Webcam Replacement, Upper Case: step 6, image 2 of 3 One Education Infinity Webcam Replacement, Upper Case: step 6, image 3 of 3
      • Flip open the laptop so that the screen is exposed.
      • We found it convenient to flip the laptop into tablet mode for added support.
      • Using a spudger, remove the six screw covers along the bezel of the screen.
      Ask FixBot
    2. One Education Infinity Webcam Replacement: step 7, image 1 of 2 One Education Infinity Webcam Replacement: step 7, image 2 of 2
      • Remove the six 2.8 mm Phillips #00 screws along the bezel.
      Ask FixBot
    3. One Education Infinity Webcam Replacement: step 8, image 1 of 3 One Education Infinity Webcam Replacement: step 8, image 2 of 3 One Education Infinity Webcam Replacement: step 8, image 3 of 3
      • Use the two tabs on the top edge of the screen to pry the case apart.
      • Once the two top clips have been disengaged, start to work your way around the rest of the screen.
      Ask FixBot
    4. One Education Infinity Webcam Replacement: step 9, image 1 of 1
      • Once all the clips have been popped off, remove the upper case from the back of the display assembly.
      • You may want to close the laptop while disconnecting the hinge-side edge, as it will give you extra clearance for the upper case.
      Ask FixBot
    1. One Education Infinity Webcam Replacement, Webcam: step 10, image 1 of 3 One Education Infinity Webcam Replacement, Webcam: step 10, image 2 of 3 One Education Infinity Webcam Replacement, Webcam: step 10, image 3 of 3
      • Remove the two 3.3 mm Phillips #00 screws holding down the webcam mount.
      • Peel off the two pieces of tape holding down the webcam wire just to the left of the webcam.
      Ask FixBot
    2. One Education Infinity Webcam Replacement: step 11, image 1 of 2 One Education Infinity Webcam Replacement: step 11, image 2 of 2
      • Remove the silver 2.7 mm screw from the circuit board beside the webcam with a Phillips #00 screwdriver.
      Ask FixBot
    3. One Education Infinity Webcam Replacement: step 12, image 1 of 3 One Education Infinity Webcam Replacement: step 12, image 2 of 3 One Education Infinity Webcam Replacement: step 12, image 3 of 3
      • Unplug the webcam cable from the circuit board by pulling it horizontally from its connector.
      Ask FixBot
    4. One Education Infinity Webcam Replacement: step 13, image 1 of 1
      • Lift the webcam up from the upper case assembly to remove.
      Ask FixBot
Austin Blakely
23,462 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 57
All Time: 460
