In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Introduction
Go to step 1 ↓This prerequisite guide for the One Education: Infinity showcases the process of disconnecting the display assembly from the upper portion of the hinge mechanism for removal.
Additionally, note that this guide has the user remove the battery prior to disassembling the upper case to prevent any electrical damage while disconnecting the display cables. However, the same effect can be achieved by simply disconnecting the battery cable, so the battery removal in step 5 can be skipped to save a bit of time and effort.
Tools
Spudger4.9
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
Flip open the laptop so that the screen is exposed.
Using a spudger, remove the six screw covers along the bezel of the screen.
Remove the twelve 3.8 mm Phillips #00 screws from the hinge brackets extending along the height of the display.
