One Education Infinity Speakers Replacement
    1. One Education Infinity Speakers Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Speakers Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Speakers Replacement, Back Case: step 1, image 3 of 3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      Ask FixBot
    2. One Education Infinity Speakers Replacement: step 2, image 1 of 2 One Education Infinity Speakers Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      Ask FixBot
    3. One Education Infinity Speakers Replacement: step 3, image 1 of 3 One Education Infinity Speakers Replacement: step 3, image 2 of 3 One Education Infinity Speakers Replacement: step 3, image 3 of 3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      Ask FixBot
    1. One Education Infinity Speakers Replacement, Battery: step 4, image 1 of 3 One Education Infinity Speakers Replacement, Battery: step 4, image 2 of 3 One Education Infinity Speakers Replacement, Battery: step 4, image 3 of 3
      • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
      • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
      Ask FixBot
    2. One Education Infinity Speakers Replacement: step 5, image 1 of 3 One Education Infinity Speakers Replacement: step 5, image 2 of 3 One Education Infinity Speakers Replacement: step 5, image 3 of 3
      • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
      • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
      • Lift the battery out from the internal case.
      Ask FixBot
    1. One Education Infinity Speakers Replacement, Solid State Drive: step 6, image 1 of 3 One Education Infinity Speakers Replacement, Solid State Drive: step 6, image 2 of 3 One Education Infinity Speakers Replacement, Solid State Drive: step 6, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
      Ask FixBot
    2. One Education Infinity Speakers Replacement: step 7, image 1 of 3 One Education Infinity Speakers Replacement: step 7, image 2 of 3 One Education Infinity Speakers Replacement: step 7, image 3 of 3
      • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
      Ask FixBot
    1. One Education Infinity Speakers Replacement, Motherboard: step 8, image 1 of 2 One Education Infinity Speakers Replacement, Motherboard: step 8, image 2 of 2
      • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
      Ask FixBot
    2. One Education Infinity Speakers Replacement: step 9, image 1 of 1
      • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
      Ask FixBot
    3. One Education Infinity Speakers Replacement: step 10, image 1 of 1
      • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
      Ask FixBot
    4. One Education Infinity Speakers Replacement: step 11, image 1 of 1
      • Using your fingers, carefully unplug the two speaker wires from the motherboard.
      Ask FixBot
    5. One Education Infinity Speakers Replacement: step 12, image 1 of 2 One Education Infinity Speakers Replacement: step 12, image 2 of 2
      • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
      Ask FixBot
    6. One Education Infinity Speakers Replacement: step 13, image 1 of 1
      • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
      Ask FixBot
    7. One Education Infinity Speakers Replacement: step 14, image 1 of 2 One Education Infinity Speakers Replacement: step 14, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
      • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
      • Using your fingers, carefully lift the motherboard out of the internal panel.
      Ask FixBot
    1. One Education Infinity Speakers Replacement, Speakers: step 15, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
      Ask FixBot
    2. One Education Infinity Speakers Replacement: step 16, image 1 of 2 One Education Infinity Speakers Replacement: step 16, image 2 of 2
      • Peel back the black tape.
      • Using your fingers, carefully lift the metal plate out of the internal panel.
      Ask FixBot
    3. One Education Infinity Speakers Replacement: step 17, image 1 of 3 One Education Infinity Speakers Replacement: step 17, image 2 of 3 One Education Infinity Speakers Replacement: step 17, image 3 of 3
      • Using your fingers, carefully lift the two speakers out of the internal panel.
      Ask FixBot
Jacob Barnes
193 Reputation
2 Guides authored
Cal Poly, Team S11-G4, Regan Fall 2019 Member of Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 424
