Up to 20% off select tools
One Education Infinity Handle Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
56
All Time:
438
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this guide you will learn how to replace the handle of your One Education Infinity. The handle is connected to the lower case with springs and Phillips #00 screws so it has give but is very secure. In the event that the handle becomes damaged, the process is very easy to replace. Be sure to power off and unplug your laptop prior to doing any work on your laptop, even the handle.
    1. One Education Infinity Handle Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Handle Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Handle Replacement, Back Case: step 1, image 3 of 3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      Ask FixBot
    2. One Education Infinity Handle Replacement: step 2, image 1 of 2 One Education Infinity Handle Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      Ask FixBot
    3. One Education Infinity Handle Replacement: step 3, image 1 of 3 One Education Infinity Handle Replacement: step 3, image 2 of 3 One Education Infinity Handle Replacement: step 3, image 3 of 3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      Ask FixBot
    1. One Education Infinity Handle Replacement, Handle: step 4, image 1 of 3 One Education Infinity Handle Replacement, Handle: step 4, image 2 of 3 One Education Infinity Handle Replacement, Handle: step 4, image 3 of 3
      • Using the Phillips #00, remove the two 4.7 mm screws securing the handle to the case.
      Ask FixBot
    2. One Education Infinity Handle Replacement: step 5, image 1 of 2 One Education Infinity Handle Replacement: step 5, image 2 of 2
      • Remove the handle from the device.
      Ask FixBot
Sarah Westberg
43,993 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 56
All Time: 438
