One Education Infinity CMOS Battery Replacement
    1. One Education Infinity CMOS Battery Replacement, Back Case: step 1, image 1 of 3 One Education Infinity CMOS Battery Replacement, Back Case: step 1, image 2 of 3 One Education Infinity CMOS Battery Replacement, Back Case: step 1, image 3 of 3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      Ask FixBot
    2. One Education Infinity CMOS Battery Replacement: step 2, image 1 of 2 One Education Infinity CMOS Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      Ask FixBot
    3. One Education Infinity CMOS Battery Replacement: step 3, image 1 of 3 One Education Infinity CMOS Battery Replacement: step 3, image 2 of 3 One Education Infinity CMOS Battery Replacement: step 3, image 3 of 3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      Ask FixBot
    1. One Education Infinity CMOS Battery Replacement, Battery: step 4, image 1 of 3 One Education Infinity CMOS Battery Replacement, Battery: step 4, image 2 of 3 One Education Infinity CMOS Battery Replacement, Battery: step 4, image 3 of 3
      • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
      • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
      Ask FixBot
    2. One Education Infinity CMOS Battery Replacement: step 5, image 1 of 3 One Education Infinity CMOS Battery Replacement: step 5, image 2 of 3 One Education Infinity CMOS Battery Replacement: step 5, image 3 of 3
      • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
      • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
      • Lift the battery out from the internal case.
      Ask FixBot
    1. One Education Infinity CMOS Battery Replacement, CMOS Battery: step 6, image 1 of 3 One Education Infinity CMOS Battery Replacement, CMOS Battery: step 6, image 2 of 3 One Education Infinity CMOS Battery Replacement, CMOS Battery: step 6, image 3 of 3
      • Use a plastic spudger to slide out the cable connector attached to the CMOS battery from the motherboard.
      Ask FixBot
    2. One Education Infinity CMOS Battery Replacement: step 7, image 1 of 3 One Education Infinity CMOS Battery Replacement: step 7, image 2 of 3 One Education Infinity CMOS Battery Replacement: step 7, image 3 of 3
      • Peel the CMOS battery gently from the back case, as there is a layer of light adhesive holding it down.
      • Remove the CMOS battery.
      Ask FixBot
Austin Blakely
23,216 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 645
