Up to 20% off select tools
One Education Infinity Back Case Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
55
All Time:
559
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you are going to replace any of the components in the One Education Infinity, you will need to remove the back case first. After removing the back case, remove the battery as a safety precaution to prevent the risk of electric shock as you work on your device (even if you are only replacing the display assembly).
    1. One Education Infinity Back Case Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Back Case Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Back Case Replacement, Back Case: step 1, image 3 of 3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      Ask FixBot
    2. One Education Infinity Back Case Replacement: step 2, image 1 of 2 One Education Infinity Back Case Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      Ask FixBot
    3. One Education Infinity Back Case Replacement: step 3, image 1 of 3 One Education Infinity Back Case Replacement: step 3, image 2 of 3 One Education Infinity Back Case Replacement: step 3, image 3 of 3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      Ask FixBot
Sarah Westberg
43,993 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 55
All Time: 559
