Up to 20% off select tools
Onda VI10 Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
85
All Time:
845
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
In this guide will detail the steps necessary to replace the glass screen on the front of the Onda VI10.
    1. Onda VI10  Screen Replacement, Screen: step 1, image 1 of 1
      • Remove four Phillips head screws from back with #0 screw driver.
      Ask FixBot
    2. Onda VI10  Screen Replacement: step 2, image 1 of 2 Onda VI10  Screen Replacement: step 2, image 2 of 2
      • Separate the back from the screen and open as shown. Make sure to open from the side with the power button to avoid damaging the ribbon cables.
      Ask FixBot
    3. Onda VI10  Screen Replacement: step 3, image 1 of 1
      • Using the plastic spudger, lift the black latches for the ribbon cables and slide the cables out of their sockets. Now the two halves can be separated.
      Ask FixBot
    4. Onda VI10  Screen Replacement: step 4, image 1 of 1
      • There are 14 3mm long screws surrounding the screen. Using the #00 Phillips screwdriver, remove all of these screws.
      Ask FixBot
    5. Onda VI10  Screen Replacement: step 5, image 1 of 1
      • Using the metal spudger, depress the four plastic tabs to free the glass from the display.
      Ask FixBot
    6. Onda VI10  Screen Replacement: step 6, image 1 of 1
      • Use the metal spudger again to get between the glass and the chrome trim ring. Lightly pry the glass away from the display. If this proves difficult, double check that all of the screws have been removed and that all four plastic clips are pushed in. Again, start from the side opposite the ribbon cable to avoid damaging it.
      Ask FixBot
    7. Onda VI10  Screen Replacement: step 7, image 1 of 1
      • Once the glass and display have been separated, pull the glass away from the display and carefully slide the ribbon cable out of the display housing.
      Ask FixBot
Author
with
Solomon Hunter
101 Reputation
1 Guide authored
IUPUI, Team S4-G3, Baechle Spring 2017 Member of IUPUI, Team S4-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 85
All Time: 845
