Up to 20% off select tools
OnHub Speaker Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
91
All Time:
1,400
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
In this guide we will explain the steps necessary to safely remove and replace the OnHub speaker.
    1. OnHub Speaker Replacement, Speaker Grille: step 1, image 1 of 2 OnHub Speaker Replacement, Speaker Grille: step 1, image 2 of 2
      • Make sure the device is unplugged before proceeding with the disassembly.
      • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
      Ask FixBot
    2. OnHub Speaker Replacement: step 2, image 1 of 1
      • Place the plastic opening tool under the speaker grille, and just above the light ring.
      • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
      Ask FixBot
    3. OnHub Speaker Replacement: step 3, image 1 of 2 OnHub Speaker Replacement: step 3, image 2 of 2
      • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
      • There is a delicate wire connection to the antenna that is easily broken if not careful.
      Ask FixBot
    1. OnHub Speaker Replacement, Congestion-sensing Antenna: step 4, image 1 of 2 OnHub Speaker Replacement, Congestion-sensing Antenna: step 4, image 2 of 2
      • Remove the wire connection to the antenna by soldering it off.
      • For help with soldering and de-soldering check out the iFixit Soldering Guide
      Ask FixBot
    1. OnHub Speaker Replacement, Outer Casing: step 5, image 1 of 2 OnHub Speaker Replacement, Outer Casing: step 5, image 2 of 2
      • You must remove the plastic cover found just above the speaker.
      • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
      • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
      • Though the snapping noise is normal, take care not to break these clips.
      Ask FixBot
    2. OnHub Speaker Replacement: step 6, image 1 of 1
      • Upon removing the cover, four screws and the speaker housing will be exposed.
      • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
      • This unlocks the speaker housing and antenna array from the casing.
      Ask FixBot
    3. OnHub Speaker Replacement: step 7, image 1 of 2 OnHub Speaker Replacement: step 7, image 2 of 2
      • On the bottom of the OnHub is two screws holding the casing to the base.
      • To access these screws, you must remove the rubber pad that is glued to the base.
      • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
      • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
      • The rubber pad is thin and fragile; be careful not to tear when removing.
      Ask FixBot
    4. OnHub Speaker Replacement: step 8, image 1 of 1
      • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
      Ask FixBot
    5. OnHub Speaker Replacement: step 9, image 1 of 2 OnHub Speaker Replacement: step 9, image 2 of 2
      • Once the two screws are removed from the base, it is time to split the casing apart.
      • It is okay if a couple clips break. It will still hold together with a few remaining.
      • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
      • There are three hooking style clips in total.
      Ask FixBot
    6. OnHub Speaker Replacement: step 10, image 1 of 1
      • Once unclipped, you can slide the two casing halves apart, and remove the casing.
      Ask FixBot
    1. OnHub Speaker Replacement, Speaker: step 11, image 1 of 2 OnHub Speaker Replacement, Speaker: step 11, image 2 of 2
      • Underneath the speaker is an intertwined black and white wire.
      • Disconnect the wire from its connection to the motherboard.
      Ask FixBot
    2. OnHub Speaker Replacement: step 12, image 1 of 1
      • The speaker should now easily come off with a firm grip on the OnHub device and pull.
      Ask FixBot
3 other people completed this guide.
Author
with
Mahir Abdella
331 Reputation
2 Guides authored
USF Tampa, Team 3-3, Sullivan Spring 2016 Member of USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 91
All Time: 1,400
