OnHub Speaker Grille Replacement
  1. OnHub Speaker Grille Replacement, Speaker Grille: step 1, image 1 of 2 OnHub Speaker Grille Replacement, Speaker Grille: step 1, image 2 of 2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
    Ask FixBot
  2. OnHub Speaker Grille Replacement: step 2, image 1 of 1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
    Ask FixBot
  3. OnHub Speaker Grille Replacement: step 3, image 1 of 2 OnHub Speaker Grille Replacement: step 3, image 2 of 2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
    Ask FixBot
3 other people completed this guide.
Joseph Ainsworth
544 Reputation
3 Guides authored
USF Tampa, Team 3-3, Sullivan Spring 2016 Member of USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 580
