Up to 20% off select tools
Omaker M4 Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
115
All Time:
2,226
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 seconds - 1 minute
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
When using the metal spudger to remove the battery, be sure to carefully pry along the entire side the battery so that the battery will come off without bending.
    1. Omaker M4 Battery Replacement, Back Case: step 1, image 1 of 1
      • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
      Ask FixBot
    2. Omaker M4 Battery Replacement: step 2, image 1 of 2 Omaker M4 Battery Replacement: step 2, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
      Ask FixBot
    3. Omaker M4 Battery Replacement: step 3, image 1 of 2 Omaker M4 Battery Replacement: step 3, image 2 of 2
      • Use a magnet to remove the screws after unscrewing them and place them aside.
      Ask FixBot
    4. Omaker M4 Battery Replacement: step 4, image 1 of 1
      • Carefully remove the back cover without breaking the battery wire.
      Ask FixBot
    5. Omaker M4 Battery Replacement: step 5, image 1 of 2 Omaker M4 Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
      • The battery is still attached to the back cover.
      Ask FixBot
    1. Omaker M4 Battery Replacement, Battery: step 6, image 1 of 3 Omaker M4 Battery Replacement, Battery: step 6, image 2 of 3 Omaker M4 Battery Replacement, Battery: step 6, image 3 of 3
      • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
      Ask FixBot
3 other people completed this guide.
Author
with
Carlos Pernia
170 Reputation
1 Guide authored
USF Tampa, Team 2-2, Sullivan Spring 2016 Member of USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Members
24 Guides authored
1 Guide Comment
What battery is required for this though? Is it easily found on amazon?
Mohsin - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 115
All Time: 2,226
