Olympus VR-350 Power Button Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
100
All Time:
2,189
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
This guide will show you how to remove the camera's power button so you can replace it if it is not working.
Tools
    1. Olympus VR-350 Power Button Replacement, Front Plate: step 1, image 1 of 2 Olympus VR-350 Power Button Replacement, Front Plate: step 1, image 2 of 2
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    2. Olympus VR-350 Power Button Replacement: step 2, image 1 of 1
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    3. Olympus VR-350 Power Button Replacement: step 3, image 1 of 3 Olympus VR-350 Power Button Replacement: step 3, image 2 of 3 Olympus VR-350 Power Button Replacement: step 3, image 3 of 3
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      Ask FixBot
    1. Olympus VR-350 Power Button Replacement, Back Plate: step 4, image 1 of 2 Olympus VR-350 Power Button Replacement, Back Plate: step 4, image 2 of 2
      • Use your fingers to pry open the back cover.
      • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
      • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
      Ask FixBot
    1. Olympus VR-350 Power Button Replacement, Power Button: step 5, image 1 of 2 Olympus VR-350 Power Button Replacement, Power Button: step 5, image 2 of 2
      • Remove the silver panel from the top of the camera.
      Ask FixBot
    2. Olympus VR-350 Power Button Replacement: step 6, image 1 of 1
      • Flip the silver panel over. The power button is the smaller button covered by a metal backing.
      Ask FixBot
    3. Olympus VR-350 Power Button Replacement: step 7, image 1 of 1
      • Pull the metal backing away from the silver panel.
      Ask FixBot
    4. Olympus VR-350 Power Button Replacement: step 8, image 1 of 1
      • Push the power button down and out of the silver panel with your finger.
      Ask FixBot
2 other people completed this guide.
Adri
456 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 100
All Time: 2,189
