Olympus VR-350 Lens Box Unit Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
108
All Time:
2,602
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the lens box unit on the Olympus VR-350.
Tools
    1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: step 1, image 1 of 2 Olympus VR-350 Lens Box Unit Replacement, Front Plate: step 1, image 2 of 2
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    2. Olympus VR-350 Lens Box Unit Replacement: step 2, image 1 of 1
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    3. Olympus VR-350 Lens Box Unit Replacement: step 3, image 1 of 3 Olympus VR-350 Lens Box Unit Replacement: step 3, image 2 of 3 Olympus VR-350 Lens Box Unit Replacement: step 3, image 3 of 3
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      Ask FixBot
    1. Olympus VR-350 Lens Box Unit Replacement, Back Plate: step 4, image 1 of 2 Olympus VR-350 Lens Box Unit Replacement, Back Plate: step 4, image 2 of 2
      • Use your fingers to pry open the back cover.
      • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
      • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
      Ask FixBot
    1. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: step 5, image 1 of 2 Olympus VR-350 Lens Box Unit Replacement, LCD Screen: step 5, image 2 of 2
      • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
      Ask FixBot
    2. Olympus VR-350 Lens Box Unit Replacement: step 6, image 1 of 1
      • Pull the button pad up to fully reveal the visible ribbon cable.
      • You might need to bend the button pad out of the way.
      Ask FixBot
    3. Olympus VR-350 Lens Box Unit Replacement: step 7, image 1 of 1
      • Pull out the LCD screen and the ribbon cable.
      • The ribbon cable should be easy to pull out.
      Ask FixBot
    1. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: step 8, image 1 of 1
      • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
      Ask FixBot
    2. Olympus VR-350 Lens Box Unit Replacement: step 9, image 1 of 2 Olympus VR-350 Lens Box Unit Replacement: step 9, image 2 of 2
      • Remove the orange ribbon cable from the connector on the left side of the motherboard.
      • To do this, gently lift up the small grey clasp and pull the cable ribbon.
      Ask FixBot
    3. Olympus VR-350 Lens Box Unit Replacement: step 10, image 1 of 1
      • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
      • You may need to use force to pull out the ribbon cables.
      Ask FixBot
    4. Olympus VR-350 Lens Box Unit Replacement: step 11, image 1 of 1
      • Pull the lens box up and out to remove it.
      Ask FixBot
5 other people completed this guide.
Brooke
278 Reputation
1 Guide authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
60 Guides authored
1 Guide Comment
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 108
All Time: 2,602
