Olympus VR-350 LCD Screen Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
113
All Time:
1,834
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
This guide will help you replace your LCD screen.
Tools
    1. Olympus VR-350 LCD Screen Replacement, Front Plate: step 1, image 1 of 2 Olympus VR-350 LCD Screen Replacement, Front Plate: step 1, image 2 of 2
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    2. Olympus VR-350 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    3. Olympus VR-350 LCD Screen Replacement: step 3, image 1 of 3 Olympus VR-350 LCD Screen Replacement: step 3, image 2 of 3 Olympus VR-350 LCD Screen Replacement: step 3, image 3 of 3
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      Ask FixBot
    1. Olympus VR-350 LCD Screen Replacement, Back Plate: step 4, image 1 of 2 Olympus VR-350 LCD Screen Replacement, Back Plate: step 4, image 2 of 2
      • Use your fingers to pry open the back cover.
      • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
      • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
      Ask FixBot
    1. Olympus VR-350 LCD Screen Replacement, LCD Screen: step 5, image 1 of 2 Olympus VR-350 LCD Screen Replacement, LCD Screen: step 5, image 2 of 2
      • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
      Ask FixBot
    2. Olympus VR-350 LCD Screen Replacement: step 6, image 1 of 1
      • Pull the button pad up to fully reveal the visible ribbon cable.
      • You might need to bend the button pad out of the way.
      Ask FixBot
    3. Olympus VR-350 LCD Screen Replacement: step 7, image 1 of 1
      • Pull out the LCD screen and the ribbon cable.
      • The ribbon cable should be easy to pull out.
      Ask FixBot
Chloe
112 Reputation
1 Guide authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 113
All Time: 1,834
