Olympus VR-350 Front Plate Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
84
All Time:
1,065
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the front plate of your camera. This can help you personalize your camera, and it is also an important first step to any other repairs.
Tools
    1. Olympus VR-350 Front Plate Replacement, Front Plate: step 1, image 1 of 2 Olympus VR-350 Front Plate Replacement, Front Plate: step 1, image 2 of 2
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    2. Olympus VR-350 Front Plate Replacement: step 2, image 1 of 1
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      Ask FixBot
    3. Olympus VR-350 Front Plate Replacement: step 3, image 1 of 3 Olympus VR-350 Front Plate Replacement: step 3, image 2 of 3 Olympus VR-350 Front Plate Replacement: step 3, image 3 of 3
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      Ask FixBot
Adri
456 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 84
All Time: 1,065
