Olympus Stylus Tough-6000 On/Off Button Replacement
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: step 1, image 1 of 1
    • First sit the camera on its bottom. You will be working on the on/off button.
    Ask FixBot
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: step 2, image 1 of 1
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
    Ask FixBot
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: step 3, image 1 of 1
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
    Ask FixBot
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: step 4, image 1 of 1
    • Grab your plastic opening tool and start prying off the panel.
    Ask FixBot
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: step 5, image 1 of 1
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
    Ask FixBot
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: step 6, image 1 of 1
    • You have reached the on/off button.
    • You can now replace it!
    Ask FixBot
Shannon Cooney
355 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,019
