Olympus Stylus 760 LCD Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
66
All Time:
2,569
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Olympus Stylus 760 LCD Screen Replacement, Battery door: step 1, image 1 of 1
      • Slide the door located on the bottom of the camera in an outward direction
      Ask FixBot
    2. Olympus Stylus 760 LCD Screen Replacement, Release: step 2, image 1 of 1
      • Pull back on the red release tab located on the left side of the battery.
      Ask FixBot
    3. Olympus Stylus 760 LCD Screen Replacement, Replacement: step 3, image 1 of 1
      • Slide battery out of camera
      Ask FixBot
    1. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
      • Remove the 2 screws from the bottom of the camera
      Ask FixBot
    2. Olympus Stylus 760 LCD Screen Replacement: step 5, image 1 of 1
      • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
      Ask FixBot
    3. Olympus Stylus 760 LCD Screen Replacement: step 6, image 1 of 1
      • Remove the 2 screws from the left side of the camera
      Ask FixBot
    4. Olympus Stylus 760 LCD Screen Replacement: step 7, image 1 of 3 Olympus Stylus 760 LCD Screen Replacement: step 7, image 2 of 3 Olympus Stylus 760 LCD Screen Replacement: step 7, image 3 of 3
      • Separate the front casing from the back using a plastic opening tool, gently.
      • Silver band and buttons will become loose when you remove the two pieces.
      Ask FixBot
    5. Olympus Stylus 760 LCD Screen Replacement: step 8, image 1 of 2 Olympus Stylus 760 LCD Screen Replacement: step 8, image 2 of 2
      • Pull the silver bracket off of the camera
      Ask FixBot
    6. Olympus Stylus 760 LCD Screen Replacement: step 9, image 1 of 3 Olympus Stylus 760 LCD Screen Replacement: step 9, image 2 of 3 Olympus Stylus 760 LCD Screen Replacement: step 9, image 3 of 3
      • Remove the 4 screws on the inner face of the camera.
      • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
      • Pull the camera apart into 2 separate pieces.
      Ask FixBot
    7. Olympus Stylus 760 LCD Screen Replacement: step 10, image 1 of 1
      • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
      Ask FixBot
    8. Olympus Stylus 760 LCD Screen Replacement: step 11, image 1 of 2 Olympus Stylus 760 LCD Screen Replacement: step 11, image 2 of 2
      • Remove 4 screws holding the LCD screen in place.
      • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
      • LCD Screen is attached to 2 ribbon wires
      Ask FixBot
    9. Olympus Stylus 760 LCD Screen Replacement: step 12, image 1 of 2 Olympus Stylus 760 LCD Screen Replacement: step 12, image 2 of 2
      • Pull up on the small ribbon wire to disconnect it from the circuit board
      • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
      Ask FixBot
    10. Olympus Stylus 760 LCD Screen Replacement: step 13, image 1 of 1
      • Using a plastic separating tool, remove the LCD screen from the plastic casing.
      Ask FixBot
Ryan Cosgrove
39 Reputation
1 Guide authored
1 Guide Comment
from where i can get repaired u760 camera
tahir zafar - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 66
All Time: 2,569
