Olympus Stylus 1030 SW LCD and Button Replacement
    1. Olympus Stylus 1030 SW LCD and Button Replacement, Olympus Stylus 1030 SW Camera Disassembly: step 1, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement, Olympus Stylus 1030 SW Camera Disassembly: step 1, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement, Olympus Stylus 1030 SW Camera Disassembly: step 1, image 3 of 3
      • Using the iFixit Opening Tool, pry off the plastic part of the lens.
      • Using the T6 Torx screwdriver, unscrew the three screws.
      Ask FixBot
    2. Olympus Stylus 1030 SW LCD and Button Replacement: step 2, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 2, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Using the Phillips #00 screwdriver, unscrew the three screws.
      • Carefully swivel the metal cover out towards you.
      • Using tweezers, remove the metal washer.
      Ask FixBot
    3. Olympus Stylus 1030 SW LCD and Button Replacement: step 3, image 1 of 2 Olympus Stylus 1030 SW LCD and Button Replacement: step 3, image 2 of 2
      • Using the tweezers, slowly peel off the plate.
      Ask FixBot
    4. Olympus Stylus 1030 SW LCD and Button Replacement: step 4, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 4, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 4, image 3 of 3
      • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
      Ask FixBot
    5. Olympus Stylus 1030 SW LCD and Button Replacement: step 5, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 5, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 5, image 3 of 3
      • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
      • Take out the speaker plate.
      • Open the multi-connector cover and slide off the side panel.
      Ask FixBot
    6. Olympus Stylus 1030 SW LCD and Button Replacement: step 6, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 6, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 6, image 3 of 3
      • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
      • On the bottom side of the camera, unscrew the two screws.
      Ask FixBot
    7. Olympus Stylus 1030 SW LCD and Button Replacement: step 7, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 7, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 7, image 3 of 3
      • Open the battery compartment cover.
      • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
      Ask FixBot
    8. Olympus Stylus 1030 SW LCD and Button Replacement: step 8, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 8, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 8, image 3 of 3
      • On the front of the camera, unscrew the two screws shown.
      • Gently pull on the side until the camera is separated from the back panel.
      • Remove the shutter and power button.
      Ask FixBot
    9. Olympus Stylus 1030 SW LCD and Button Replacement: step 9, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 9, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 9, image 3 of 3
      • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
      • Unscrew the shutter using the Phillips #00 screwdriver.
      Ask FixBot
    10. Olympus Stylus 1030 SW LCD and Button Replacement: step 10, image 1 of 2 Olympus Stylus 1030 SW LCD and Button Replacement: step 10, image 2 of 2
      • Release the top holding using a spudger.
      • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
      Ask FixBot
    11. Olympus Stylus 1030 SW LCD and Button Replacement: step 11, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 11, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 11, image 3 of 3
      • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
      Ask FixBot
    1. Olympus Stylus 1030 SW LCD and Button Replacement, LCD and Buttons: step 12, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement, LCD and Buttons: step 12, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement, LCD and Buttons: step 12, image 3 of 3
      Buy
      • Unscrew the two screws found on the left side of the screen using the PH#00 head.
      • Peel off the gel tape using tweezers.
      • Unscrew the five 0.6 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    2. Olympus Stylus 1030 SW LCD and Button Replacement: step 13, image 1 of 2 Olympus Stylus 1030 SW LCD and Button Replacement: step 13, image 2 of 2
      • Use the spudger to carefully pry off the LCD screen.
      Ask FixBot
    3. Olympus Stylus 1030 SW LCD and Button Replacement: step 14, image 1 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 14, image 2 of 3 Olympus Stylus 1030 SW LCD and Button Replacement: step 14, image 3 of 3
      • Use the tweezers to take out the rubber button holder and its buttons.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 115
All Time: 1,912
