Olympus Stylus 1030 SW AV Port Replacement
  1. Olympus Stylus 1030 SW AV Port Replacement, AV Port: step 1, image 1 of 3 Olympus Stylus 1030 SW AV Port Replacement, AV Port: step 1, image 2 of 3 Olympus Stylus 1030 SW AV Port Replacement, AV Port: step 1, image 3 of 3
    • Use your screwdriver with a Phillips #00 screwdriver to remove all three screws.
    • Use your hand to lift and remove the front case.
    Ask FixBot
  2. Olympus Stylus 1030 SW AV Port Replacement: step 2, image 1 of 3 Olympus Stylus 1030 SW AV Port Replacement: step 2, image 2 of 3 Olympus Stylus 1030 SW AV Port Replacement: step 2, image 3 of 3
    • Remove the rear case.
    • Use a Phillips #00 screwdriver to remove both screws from the side panel.
    • Remove both screws from the battery door.
    Ask FixBot
  3. Olympus Stylus 1030 SW AV Port Replacement: step 3, image 1 of 1
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
    Ask FixBot
  4. Olympus Stylus 1030 SW AV Port Replacement: step 4, image 1 of 2 Olympus Stylus 1030 SW AV Port Replacement: step 4, image 2 of 2
    • Flip your camera with the rear side facing away from you. Take your screw driver with the #00 size to remove both screws.
    • Remove the front case.
    Ask FixBot
  5. Olympus Stylus 1030 SW AV Port Replacement: step 5, image 1 of 3 Olympus Stylus 1030 SW AV Port Replacement: step 5, image 2 of 3 Olympus Stylus 1030 SW AV Port Replacement: step 5, image 3 of 3
    • Start with the rear end facing away from you.
    • Use a Phillips #00 size to remove both screws.
    • Flip the camera to the front facing you.
    • Remove the single Phillips #00 screw.
    Ask FixBot
  6. Olympus Stylus 1030 SW AV Port Replacement: step 6, image 1 of 3 Olympus Stylus 1030 SW AV Port Replacement: step 6, image 2 of 3 Olympus Stylus 1030 SW AV Port Replacement: step 6, image 3 of 3
    • To get to the AV port use a spudger to separate the camera.
    Ask FixBot
  7. Olympus Stylus 1030 SW AV Port Replacement: step 7, image 1 of 2 Olympus Stylus 1030 SW AV Port Replacement: step 7, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the remaining two screws from the motherboard.
    Ask FixBot
  8. Olympus Stylus 1030 SW AV Port Replacement: step 8, image 1 of 2 Olympus Stylus 1030 SW AV Port Replacement: step 8, image 2 of 2
    • Use your fingers to lift the black flap and use a Phillips #00 screwdriver to remove the two screws.
    Ask FixBot
  9. Olympus Stylus 1030 SW AV Port Replacement: step 9, image 1 of 2 Olympus Stylus 1030 SW AV Port Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • With your tweezers from your kit, take out the motherboard of the camera.
    • Once the motherboard is removed separate the motherboard.
    • The AV port is visible, use your spatula to wedge between the AV port to remove.
    Ask FixBot
Alexis Sulzle
301 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 51
All Time: 308
