Olympus Stylus 1010 Lens Replacement
    1. Olympus Stylus 1010 Lens Replacement, Disassembling Olympus Stylus 1010 Case: step 1, image 1 of 2 Olympus Stylus 1010 Lens Replacement, Disassembling Olympus Stylus 1010 Case: step 1, image 2 of 2
      • Remove the five Phillips #00 bottom and right side panel screws.
      Ask FixBot
    2. Olympus Stylus 1010 Lens Replacement: step 2, image 1 of 1
      • Remove the right side panel by pulling off the large silver piece.
      Ask FixBot
    3. Olympus Stylus 1010 Lens Replacement: step 3, image 1 of 2 Olympus Stylus 1010 Lens Replacement: step 3, image 2 of 2
      • Remove the remaining three Phillips #00 side and front panel screws.
      Ask FixBot
    4. Olympus Stylus 1010 Lens Replacement: step 4, image 1 of 1
      • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
      Ask FixBot
    5. Olympus Stylus 1010 Lens Replacement: step 5, image 1 of 1
      • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
      Ask FixBot
    6. Olympus Stylus 1010 Lens Replacement: step 6, image 1 of 3 Olympus Stylus 1010 Lens Replacement: step 6, image 2 of 3 Olympus Stylus 1010 Lens Replacement: step 6, image 3 of 3
      • Remove the three Phillips #00 screws from the front of the camera.
      • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
      Ask FixBot
    7. Olympus Stylus 1010 Lens Replacement: step 7, image 1 of 3 Olympus Stylus 1010 Lens Replacement: step 7, image 2 of 3 Olympus Stylus 1010 Lens Replacement: step 7, image 3 of 3
      • Using a plastic spudger, lift up the black clips.
      • Still using the plastic spudger, detach the gold connector strip and white connector strip.
      • Using both hands, pull the camera apart into two pieces.
      Ask FixBot
    1. Olympus Stylus 1010 Lens Replacement, Lens: step 8, image 1 of 2 Olympus Stylus 1010 Lens Replacement, Lens: step 8, image 2 of 2
      • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
      Ask FixBot
    2. Olympus Stylus 1010 Lens Replacement: step 9, image 1 of 1
      • Remove the three screws from the inside of the camera using a #00 screwdriver.
      Ask FixBot
    3. Olympus Stylus 1010 Lens Replacement: step 10, image 1 of 2 Olympus Stylus 1010 Lens Replacement: step 10, image 2 of 2
      • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
      Ask FixBot
2 other people completed this guide.
Max McIntyre
544 Reputation
4 Guides authored
Cal Poly, Team 13-4, Forte Winter 2011 Member of Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Members
71 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 6,650
