Olympus Stylus 1010 Flash Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
3,268
Comments: 8
8 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will help you to replace the flash device on your Olympus Stylus 1010.
Tools
    1. Olympus Stylus 1010 Flash Replacement, Disassembling Olympus Stylus 1010 Case: step 1, image 1 of 2 Olympus Stylus 1010 Flash Replacement, Disassembling Olympus Stylus 1010 Case: step 1, image 2 of 2
      • Remove the five Phillips #00 bottom and right side panel screws.
      Ask FixBot
    2. Olympus Stylus 1010 Flash Replacement: step 2, image 1 of 1
      • Remove the right side panel by pulling off the large silver piece.
      Ask FixBot
    3. Olympus Stylus 1010 Flash Replacement: step 3, image 1 of 2 Olympus Stylus 1010 Flash Replacement: step 3, image 2 of 2
      • Remove the remaining three Phillips #00 side and front panel screws.
      Ask FixBot
    4. Olympus Stylus 1010 Flash Replacement: step 4, image 1 of 1
      • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
      Ask FixBot
    5. Olympus Stylus 1010 Flash Replacement: step 5, image 1 of 1
      • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
      Ask FixBot
    6. Olympus Stylus 1010 Flash Replacement: step 6, image 1 of 3 Olympus Stylus 1010 Flash Replacement: step 6, image 2 of 3 Olympus Stylus 1010 Flash Replacement: step 6, image 3 of 3
      • Remove the three Phillips #00 screws from the front of the camera.
      • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
      Ask FixBot
    7. Olympus Stylus 1010 Flash Replacement: step 7, image 1 of 3 Olympus Stylus 1010 Flash Replacement: step 7, image 2 of 3 Olympus Stylus 1010 Flash Replacement: step 7, image 3 of 3
      • Using a plastic spudger, lift up the black clips.
      • Still using the plastic spudger, detach the gold connector strip and white connector strip.
      • Using both hands, pull the camera apart into two pieces.
      Ask FixBot
    1. Olympus Stylus 1010 Flash Replacement, Lens: step 8, image 1 of 2 Olympus Stylus 1010 Flash Replacement, Lens: step 8, image 2 of 2
      • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
      Ask FixBot
    2. Olympus Stylus 1010 Flash Replacement: step 9, image 1 of 1
      • Remove the three screws from the inside of the camera using a #00 screwdriver.
      Ask FixBot
    3. Olympus Stylus 1010 Flash Replacement: step 10, image 1 of 2 Olympus Stylus 1010 Flash Replacement: step 10, image 2 of 2
      • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
      Ask FixBot
    1. Olympus Stylus 1010 Flash Replacement, Motherboard: step 11, image 1 of 1
      • Remove the two Phillips #00 screws on the right side of the camera.
      Ask FixBot
    2. Olympus Stylus 1010 Flash Replacement: step 12, image 1 of 1
      • Still using the spudger, detach the gold wire tape connectors from the motherboard.
      Ask FixBot
    3. Olympus Stylus 1010 Flash Replacement: step 13, image 1 of 1
      • Desolder the upper right and lower left wires to remove the motherboard.
      Ask FixBot
    4. Olympus Stylus 1010 Flash Replacement: step 14, image 1 of 2 Olympus Stylus 1010 Flash Replacement: step 14, image 2 of 2
      • In order to remove the motherboard, grab each side of it and pull up using your thumb and forefinger.
      Ask FixBot
    1. Olympus Stylus 1010 Flash Replacement, Flash: step 15, image 1 of 3 Olympus Stylus 1010 Flash Replacement, Flash: step 15, image 2 of 3 Olympus Stylus 1010 Flash Replacement, Flash: step 15, image 3 of 3
      • Remove the two remaining Phillips #00 screws.
      • Lift the metal piece straight up to remove it.
      Ask FixBot
    2. Olympus Stylus 1010 Flash Replacement: step 16, image 1 of 3 Olympus Stylus 1010 Flash Replacement: step 16, image 2 of 3 Olympus Stylus 1010 Flash Replacement: step 16, image 3 of 3
      • Pull gently on the white tab to remove the small motherboard with the flash device on it.
      Ask FixBot
    3. Olympus Stylus 1010 Flash Replacement: step 17, image 1 of 2 Olympus Stylus 1010 Flash Replacement: step 17, image 2 of 2
      • Pull out the silver button using your thumb and forefinger.
      • Remove the small motherboard from the camera casing.
      Ask FixBot
    4. Olympus Stylus 1010 Flash Replacement: step 18, image 1 of 3 Olympus Stylus 1010 Flash Replacement: step 18, image 2 of 3 Olympus Stylus 1010 Flash Replacement: step 18, image 3 of 3
      • Remove the plastic flash cover using a spudger.
      Ask FixBot
    5. Olympus Stylus 1010 Flash Replacement: step 19, image 1 of 2 Olympus Stylus 1010 Flash Replacement: step 19, image 2 of 2
      • Remove the flash bulb using a plastic spudger.
      Ask FixBot
Curtis Reedy
270 Reputation
2 Guides authored
Cal Poly, Team 13-4, Forte Winter 2011 Member of Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 3,268
