Olympus SZ-12 Lens Replacement
  1. Olympus SZ-12 Lens Replacement, Back Case: step 1, image 1 of 2 Olympus SZ-12 Lens Replacement, Back Case: step 1, image 2 of 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
    Ask FixBot
  2. Olympus SZ-12 Lens Replacement: step 2, image 1 of 1
    • There are four screws to take out on the bottom of the camera.
    Ask FixBot
  3. Olympus SZ-12 Lens Replacement: step 3, image 1 of 1
    • There are three screws to take out on this side.
    Ask FixBot
  4. Olympus SZ-12 Lens Replacement: step 4, image 1 of 1
    • There is one screw to take out on this side.
    Ask FixBot
  5. Olympus SZ-12 Lens Replacement: step 5, image 1 of 1
    • There is one hidden screw inside the HDMI port.
    Ask FixBot
  6. Olympus SZ-12 Lens Replacement: step 6, image 1 of 1
    • Using the blue plastic opening tool, wedge open and remove the case.
    Ask FixBot
  7. Olympus SZ-12 Lens Replacement, LCD Screen: step 7, image 1 of 1
    • Once you have the back case off, remove the LCD Screen.
    Ask FixBot
  8. Olympus SZ-12 Lens Replacement: step 8, image 1 of 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
    Ask FixBot
  9. Olympus SZ-12 Lens Replacement: step 9, image 1 of 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
    Ask FixBot
  10. Olympus SZ-12 Lens Replacement, Lens: step 10, image 1 of 2 Olympus SZ-12 Lens Replacement, Lens: step 10, image 2 of 2
    • Remove the four 3.8mm Phillips #000 screws from the LCD frame.
    Ask FixBot
  11. Olympus SZ-12 Lens Replacement: step 11, image 1 of 3 Olympus SZ-12 Lens Replacement: step 11, image 2 of 3 Olympus SZ-12 Lens Replacement: step 11, image 3 of 3
    • Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
    Ask FixBot
  12. Olympus SZ-12 Lens Replacement: step 12, image 1 of 3 Olympus SZ-12 Lens Replacement: step 12, image 2 of 3 Olympus SZ-12 Lens Replacement: step 12, image 3 of 3
    • Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
    Ask FixBot
  13. Olympus SZ-12 Lens Replacement: step 13, image 1 of 1
    • Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
    • Remove the lens frame.
    Ask FixBot
  14. Olympus SZ-12 Lens Replacement: step 14, image 1 of 3 Olympus SZ-12 Lens Replacement: step 14, image 2 of 3 Olympus SZ-12 Lens Replacement: step 14, image 3 of 3
    • Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
    • Remove the lens.
    Ask FixBot
3 other people completed this guide.
1 Guide Comment
Is her anything in the lens assembly that I could look for which may have dislodged showing up as a shadow on the bottom of the display screen
Deacon - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 63
All Time: 2,501
