Olympus SP-320 Motherboard Replacement
  1. Olympus SP-320 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Olympus SP-320 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Olympus SP-320 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
    Ask FixBot
  2. Olympus SP-320 Motherboard Replacement: step 2, image 1 of 1
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
    Ask FixBot
  3. Olympus SP-320 Motherboard Replacement: step 3, image 1 of 2 Olympus SP-320 Motherboard Replacement: step 3, image 2 of 2
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
    Ask FixBot
  4. Olympus SP-320 Motherboard Replacement: step 4, image 1 of 3 Olympus SP-320 Motherboard Replacement: step 4, image 2 of 3 Olympus SP-320 Motherboard Replacement: step 4, image 3 of 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
    Ask FixBot
  5. Olympus SP-320 Motherboard Replacement: step 5, image 1 of 2 Olympus SP-320 Motherboard Replacement: step 5, image 2 of 2
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    Ask FixBot
  6. Olympus SP-320 Motherboard Replacement: step 6, image 1 of 1
    • Remove motherboard.
    Ask FixBot
2 other people completed this guide.
2 Guide Comments
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - Reply Share
It would be nice to know why you needed to access the motherboard.
John - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 41
All Time: 977
