Introduction
Go to step 1 ↓Use this guide to replace a damaged back case, or open the case to access other components of your camera.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Tools
Spudger4.9
Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
4 other people completed this guide.
2 Guide Comments
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
I should have read the comments first XD
One arm screws holding the Screen, the screws lost contact to the arm.
I did all steps, it worked perfectly!
At Step 3 the plastic parts holding the HDMI Cover fell out and I had to find out how to get it in again, but i figured it out with the good pictures here!
Thanks for that awesome work!
