Olympus FE-210 Lens Assembly Replacement
Views: 7.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
32
Past 30 Days:
145
All Time:
7,583
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
You must remove the batteries, the front casing, the rear casing, and the motherboard before removing the lens assembly.
Tools
    1. Olympus FE-210 Lens Assembly Replacement, Battery: step 1, image 1 of 2 Olympus FE-210 Lens Assembly Replacement, Battery: step 1, image 2 of 2
      • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
      Ask FixBot
    2. Olympus FE-210 Lens Assembly Replacement: step 2, image 1 of 2 Olympus FE-210 Lens Assembly Replacement: step 2, image 2 of 2
      • The batteries will slide right out.
      • When putting new batteries in, make sure they are pointing the right direction.
      Ask FixBot
    1. Olympus FE-210 Lens Assembly Replacement, Front Casing: step 3, image 1 of 3 Olympus FE-210 Lens Assembly Replacement, Front Casing: step 3, image 2 of 3 Olympus FE-210 Lens Assembly Replacement, Front Casing: step 3, image 3 of 3
      • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
      • Six screws are 3.6 mm.
      • The seventh screw is 3.2 mm.
      Ask FixBot
    2. Olympus FE-210 Lens Assembly Replacement: step 4, image 1 of 3 Olympus FE-210 Lens Assembly Replacement: step 4, image 2 of 3 Olympus FE-210 Lens Assembly Replacement: step 4, image 3 of 3
      • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
      • These three places are located:
      • At the top and bottom of the battery side (opposite of side pictured) of the case.
      • Right in the middle of the DC-in side (side pictured) of the case.
      • Top of the camera, to the left of the power button.
      • Once those places are disconnected, the front case will pop right off.
      • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
      Ask FixBot
    1. Olympus FE-210 Lens Assembly Replacement, Rear Casing: step 5, image 1 of 1
      • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
      • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
      Ask FixBot
    2. Olympus FE-210 Lens Assembly Replacement: step 6, image 1 of 3 Olympus FE-210 Lens Assembly Replacement: step 6, image 2 of 3 Olympus FE-210 Lens Assembly Replacement: step 6, image 3 of 3
      • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
      • Lift the white latch using a fingernail or a spudger.
      • Pull the cord from its connector.
      Ask FixBot
    1. Olympus FE-210 Lens Assembly Replacement, Motherboard: step 7, image 1 of 2 Olympus FE-210 Lens Assembly Replacement, Motherboard: step 7, image 2 of 2
      • Remove the 2 pieces of translucent yellow tape.
      • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
      Ask FixBot
    2. Olympus FE-210 Lens Assembly Replacement: step 8, image 1 of 2 Olympus FE-210 Lens Assembly Replacement: step 8, image 2 of 2
      • Remove the seven 2.7 mm using a #00 screwdriver.
      Ask FixBot
    3. Olympus FE-210 Lens Assembly Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
      Ask FixBot
    4. Olympus FE-210 Lens Assembly Replacement: step 10, image 1 of 1
      • Disconnect the ribbon cord located on the left side of the motherboard.
      • Use tweezers or a spudger to lift the latch on the connector.
      • Carefully remove the cord from the connector.
      Ask FixBot
    5. Olympus FE-210 Lens Assembly Replacement: step 11, image 1 of 2 Olympus FE-210 Lens Assembly Replacement: step 11, image 2 of 2
      • De-solder the 2 connection points.
      • Be careful to not damage any part of the circuit board with the soldering iron.
      Ask FixBot
    6. Olympus FE-210 Lens Assembly Replacement: step 12, image 1 of 1
      • Remove the motherboard from the camera casing.
      Ask FixBot
    1. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: step 13, image 1 of 1
      • Remove the three 3.6 mm screws using a #00 screwdriver.
      Ask FixBot
    2. Olympus FE-210 Lens Assembly Replacement: step 14, image 1 of 2 Olympus FE-210 Lens Assembly Replacement: step 14, image 2 of 2
      • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
      Ask FixBot
Matt
826 Reputation
6 Guides authored
Cal Poly, Team 4-36, Regan Winter 2011 Member of Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Members
84 Guides authored
1 Guide Comment
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - Reply Share
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 145
All Time: 7,583
