Olympus FE-210 LCD Screen Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
103
All Time:
6,367
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
Before removing the LCD screen you must first remove the rear camera casing.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Olympus FE-210 LCD Screen Replacement, Battery: step 1, image 1 of 2 Olympus FE-210 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
      Ask FixBot
    2. Olympus FE-210 LCD Screen Replacement: step 2, image 1 of 2 Olympus FE-210 LCD Screen Replacement: step 2, image 2 of 2
      • The batteries will slide right out.
      • When putting new batteries in, make sure they are pointing the right direction.
      Ask FixBot
    1. Olympus FE-210 LCD Screen Replacement, Front Casing: step 3, image 1 of 3 Olympus FE-210 LCD Screen Replacement, Front Casing: step 3, image 2 of 3 Olympus FE-210 LCD Screen Replacement, Front Casing: step 3, image 3 of 3
      • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
      • Six screws are 3.6 mm.
      • The seventh screw is 3.2 mm.
      Ask FixBot
    2. Olympus FE-210 LCD Screen Replacement: step 4, image 1 of 3 Olympus FE-210 LCD Screen Replacement: step 4, image 2 of 3 Olympus FE-210 LCD Screen Replacement: step 4, image 3 of 3
      • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
      • These three places are located:
      • At the top and bottom of the battery side (opposite of side pictured) of the case.
      • Right in the middle of the DC-in side (side pictured) of the case.
      • Top of the camera, to the left of the power button.
      • Once those places are disconnected, the front case will pop right off.
      • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
      Ask FixBot
    1. Olympus FE-210 LCD Screen Replacement, Rear Casing: step 5, image 1 of 1
      • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
      • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
      Ask FixBot
    2. Olympus FE-210 LCD Screen Replacement: step 6, image 1 of 3 Olympus FE-210 LCD Screen Replacement: step 6, image 2 of 3 Olympus FE-210 LCD Screen Replacement: step 6, image 3 of 3
      • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
      • Lift the white latch using a fingernail or a spudger.
      • Pull the cord from its connector.
      Ask FixBot
    1. Olympus FE-210 LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 Olympus FE-210 LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
      • Remove the two 2.7 mm screws using a #00 screwdriver.
      • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
      Ask FixBot
    2. Olympus FE-210 LCD Screen Replacement: step 8, image 1 of 3 Olympus FE-210 LCD Screen Replacement: step 8, image 2 of 3 Olympus FE-210 LCD Screen Replacement: step 8, image 3 of 3
      • Using a spudger, lift the latch on the connector.
      • Remove the ribbon cord from its connector.
      • Remove the LCD from the rest of the camera.
      Ask FixBot
4 other people completed this guide.
Matt
826 Reputation
6 Guides authored
Cal Poly, Team 4-36, Regan Winter 2011 Member of Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Members
84 Guides authored
1 Guide Comment
Now need source for replacement screen thank you
Emile Crotteau - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 103
All Time: 6,367
