Olympus D590 Retainer Clip Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
35
All Time:
2,643
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide shows how to replace a broken retainer clip (the plastic piece that covers the battery and XD card slot).
Tools
    1. Olympus D590 Retainer Clip Replacement, Face Plate: step 1, image 1 of 1
      • Remove five baseplate screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Olympus D590 Retainer Clip Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
      Ask FixBot
    3. Olympus D590 Retainer Clip Replacement: step 3, image 1 of 1
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
      Ask FixBot
    4. Olympus D590 Retainer Clip Replacement: step 4, image 1 of 1
      • Using tweezers, lift the rubber plate to expose the ports.
      Ask FixBot
    5. Olympus D590 Retainer Clip Replacement: step 5, image 1 of 1
      • Remove two screws from the ports using a Phillips #00 screwdriver.
      Ask FixBot
    6. Olympus D590 Retainer Clip Replacement: step 6, image 1 of 1
      • Use a spudger to pry the faceplate away from the rest of the camera.
      Ask FixBot
    7. Olympus D590 Retainer Clip Replacement: step 7, image 1 of 1
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
      Ask FixBot
    1. Olympus D590 Retainer Clip Replacement, Retainer Clip: step 8, image 1 of 1
      • Orient the camera as shown, with the bottom facing up.
      • Open the retainer clip, by using your finger to push down and slide to the left.
      • The clip should pop open.
      Ask FixBot
    2. Olympus D590 Retainer Clip Replacement: step 9, image 1 of 1
      • Hold the retainer clip down (without re-latching it).
      • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
      Ask FixBot
    3. Olympus D590 Retainer Clip Replacement: step 10, image 1 of 1
      Buy
      • Use tweezers to continue to remove the pin.
      Ask FixBot
    4. Olympus D590 Retainer Clip Replacement: step 11, image 1 of 1
      • When it feels loose, pull the pin all the way out with your fingers.
      Ask FixBot
    5. Olympus D590 Retainer Clip Replacement: step 12, image 1 of 1
      • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
      Ask FixBot
Katie
31 Reputation
3 Guides authored
Cal Poly, Team 28-23, Regan Spring 2010 Member of Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 35
All Time: 2,643
