Olympus D590 Lens Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
46
All Time:
3,066
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This guide shows how to replace the camera lens and surrounding mechanisms (including the motor) on an Olympus D590.
Tools
    1. Olympus D590 Lens Replacement, Face Plate: step 1, image 1 of 1
      • Remove five baseplate screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Olympus D590 Lens Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
      Ask FixBot
    3. Olympus D590 Lens Replacement: step 3, image 1 of 1
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
      Ask FixBot
    4. Olympus D590 Lens Replacement: step 4, image 1 of 1
      • Using tweezers, lift the rubber plate to expose the ports.
      Ask FixBot
    5. Olympus D590 Lens Replacement: step 5, image 1 of 1
      • Remove two screws from the ports using a Phillips #00 screwdriver.
      Ask FixBot
    6. Olympus D590 Lens Replacement: step 6, image 1 of 1
      • Use a spudger to pry the faceplate away from the rest of the camera.
      Ask FixBot
    7. Olympus D590 Lens Replacement: step 7, image 1 of 1
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
      Ask FixBot
    1. Olympus D590 Lens Replacement, Backplate: step 8, image 1 of 1
      • Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
      Ask FixBot
    2. Olympus D590 Lens Replacement: step 9, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
      Ask FixBot
    3. Olympus D590 Lens Replacement: step 10, image 1 of 1
      • Using an iFixit opening tool, pry the backplate from the camera internal housing component.
      Ask FixBot
    4. Olympus D590 Lens Replacement: step 11, image 1 of 1
      • Pull the backplate away from the camera internal housing component.
      Ask FixBot
    1. Olympus D590 Lens Replacement, LCD Screen: step 12, image 1 of 1
      • Remove one screw Phillips #00 from the right side of the LCD screen camera internal housing component.
      Ask FixBot
    2. Olympus D590 Lens Replacement: step 13, image 1 of 2 Olympus D590 Lens Replacement: step 13, image 2 of 2
      • To check that all screws are removed from the exterior side panel, gradually slide and lift no more than 3cm away from the camera internal component body.
      Ask FixBot
    3. Olympus D590 Lens Replacement: step 14, image 1 of 2 Olympus D590 Lens Replacement: step 14, image 2 of 2
      Buy
      • View the front of the camera internal housing component.
      • Using tweezers, detach the gray connector and blue wiring tape.
      • Be cautious to gently wiggle and pull blue wiring tape and gray wire connector during detachment.
      Ask FixBot
    4. Olympus D590 Lens Replacement: step 15, image 1 of 2 Olympus D590 Lens Replacement: step 15, image 2 of 2
      • View the top of the camera internal housing component.
      • Using tweezers, gently lift the black tape exposing all connector wires.
      Ask FixBot
    5. Olympus D590 Lens Replacement: step 16, image 1 of 1
      • View the bottom of the camera internal housing component.
      • Caution: Keep yellow taped wire attached to the LCD screen.
      • Use tweezers to gently wiggle, pull, and detach tape from the surface of the camera internal housing component.
      Ask FixBot
    6. Olympus D590 Lens Replacement: step 17, image 1 of 3 Olympus D590 Lens Replacement: step 17, image 2 of 3 Olympus D590 Lens Replacement: step 17, image 3 of 3
      • Using tweezers, gently lift the speaker, cautiously maneuvering the wire away from the side of the internal housing component toward the front of the camera internal housing component.
      Ask FixBot
    7. Olympus D590 Lens Replacement: step 18, image 1 of 2 Olympus D590 Lens Replacement: step 18, image 2 of 2
      • Gently lift the LCD screen away from the camera internal housing component hinging the thick yellow wiring tape attached to the camera internal housing component.
      • Use a forefinger and thumb to gently pull the thick yellow wiring tape out of the camera internal housing component.
      Ask FixBot
    1. Olympus D590 Lens Replacement, Lens: step 19, image 1 of 1
      • Flip the camera so you are looking at the back.
      • Looking at the back of the camera, remove the 3 screws behind the camera lens.
      Ask FixBot
    2. Olympus D590 Lens Replacement: step 20, image 1 of 1
      • Flip the camera so that the front lens is facing up.
      • Disconnect the lens from the logic board.
      Ask FixBot
    3. Olympus D590 Lens Replacement: step 21, image 1 of 1
      • Flip the camera back over so that the back of the camera is facing you, and the lens in facing away.
      • Disconnect the wire that connects the logic board to the lens assembly.
      • Gently pull back on the wire to disconnect it safely.
      Ask FixBot
    4. Olympus D590 Lens Replacement: step 22, image 1 of 1
      • Flip the camera back around so that the front is facing you.
      • Carefully lift the lens assembly out of the camera.
      Ask FixBot
Joshua
7 Reputation
2 Guides authored
Cal Poly, Team 28-23, Regan Spring 2010 Member of Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 46
All Time: 3,066
