Olympus D590 Face Plate Replacement
Views: 2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
32
All Time:
2,035
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Step-by-step Instruction Guide
Olympus D590 Camera Faceplate Removal
Access of internal housing compartment body
Tools
    1. Olympus D590 Face Plate Replacement, Face Plate: step 1, image 1 of 1
      • Remove five baseplate screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Olympus D590 Face Plate Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
      Ask FixBot
    3. Olympus D590 Face Plate Replacement: step 3, image 1 of 1
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
      Ask FixBot
    4. Olympus D590 Face Plate Replacement: step 4, image 1 of 1
      • Using tweezers, lift the rubber plate to expose the ports.
      Ask FixBot
    5. Olympus D590 Face Plate Replacement: step 5, image 1 of 1
      • Remove two screws from the ports using a Phillips #00 screwdriver.
      Ask FixBot
    6. Olympus D590 Face Plate Replacement: step 6, image 1 of 1
      • Use a spudger to pry the faceplate away from the rest of the camera.
      Ask FixBot
    7. Olympus D590 Face Plate Replacement: step 7, image 1 of 1
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
      Ask FixBot
Katie
31 Reputation
3 Guides authored
Cal Poly, Team 28-23, Regan Spring 2010 Member of Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 2,035
