Up to 20% off select tools
Olympus 850SW Memory Card Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
100
All Time:
3,400
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Make sure the camera is off.
    1. Olympus 850SW Memory Card Replacement, Memory Card: step 1, image 1 of 1
      • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
      • Make sure to remove the battery before trying to remove the memory card.
      Ask FixBot
    2. Olympus 850SW Memory Card Replacement: step 2, image 1 of 1
      • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
      Ask FixBot
    3. Olympus 850SW Memory Card Replacement: step 3, image 1 of 1
      • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
      • Insert the card into the compartment fully until it clicks into place.
      Ask FixBot
    4. Olympus 850SW Memory Card Replacement: step 4, image 1 of 1
      • Close the memory card latch/ battery latch.
      Ask FixBot
Author
with
Emma Fincken
500 Reputation
4 Guides authored
1 Guide Comment
How much gigabytes can I use on an Olympus 850 SW?
Yuan - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 100
All Time: 3,400
