Olympus 850SW Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
130
All Time:
1,681
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Ensure you have a fully charged battery, and that it is the correct battery if you have purchased a new one. This camera will accept a rechargeable Olympus LI-42B Lithium-Ion battery.
Parts
Tools
    1. Olympus 850SW Battery Replacement, Battery: step 1, image 1 of 1
      • Locate the battery compartment on the bottom panel of the camera.
      Ask FixBot
    2. Olympus 850SW Battery Replacement: step 2, image 1 of 2 Olympus 850SW Battery Replacement: step 2, image 2 of 2
      • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
      Ask FixBot
    3. Olympus 850SW Battery Replacement: step 3, image 1 of 3 Olympus 850SW Battery Replacement: step 3, image 2 of 3 Olympus 850SW Battery Replacement: step 3, image 3 of 3
      • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
      Ask FixBot
    4. Olympus 850SW Battery Replacement: step 4, image 1 of 1
      • Allow the latch to completely open and insert the battery, with the writing side up.
      • The battery slot is the bigger slot. The smaller slot is for the memory card.
      Ask FixBot
    5. Olympus 850SW Battery Replacement: step 5, image 1 of 1
      • Close the latch. You will hear a click when the compartment is fully closed.
      Ask FixBot
    6. Olympus 850SW Battery Replacement: step 6, image 1 of 1
      • Place the small black piece back in its' place.
      Ask FixBot
    7. Olympus 850SW Battery Replacement: step 7, image 1 of 1
      • Place the metal cover back over the closed latch, and screw the screw back in.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 130
All Time: 1,681
