Olympic Fencing Foil Handguard Replacement
  1. Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: step 1, image 1 of 3 Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: step 1, image 2 of 3 Olympic Fencing Foil Handguard Replacement, Olympic Fencing Foil Handguard: step 1, image 3 of 3
    • Remove the nut securing the handle with the 1 x 6 mm hex key.
    Ask FixBot
  2. Olympic Fencing Foil Handguard Replacement: step 2, image 1 of 2 Olympic Fencing Foil Handguard Replacement: step 2, image 2 of 2
    • Remove the grip and pad.
    Ask FixBot
  3. Olympic Fencing Foil Handguard Replacement: step 3, image 1 of 2 Olympic Fencing Foil Handguard Replacement: step 3, image 2 of 2
    • Use pliers to hold the hexnut still while using a flathead screwdriver to loosen the socket holding the wire.
    • Do not completely remove the socket from the socket holder.
    Ask FixBot
  4. Olympic Fencing Foil Handguard Replacement: step 4, image 1 of 3 Olympic Fencing Foil Handguard Replacement: step 4, image 2 of 3 Olympic Fencing Foil Handguard Replacement: step 4, image 3 of 3
    • Unwrap the wire from the socket.
    • Be gentle unwrapping the wire; excessive twisting may snap the wire.
    Ask FixBot
  5. Olympic Fencing Foil Handguard Replacement: step 5, image 1 of 3 Olympic Fencing Foil Handguard Replacement: step 5, image 2 of 3 Olympic Fencing Foil Handguard Replacement: step 5, image 3 of 3
    • Take the wire out under the socket holder's hole.
    • If there is tape holding down the wire, remove it.
    Ask FixBot
  6. Olympic Fencing Foil Handguard Replacement: step 6, image 1 of 3 Olympic Fencing Foil Handguard Replacement: step 6, image 2 of 3 Olympic Fencing Foil Handguard Replacement: step 6, image 3 of 3
    • Remove the socket holder.
    • Remove the old handguard.
    • Get your new handguard ready.
    Ask FixBot
  7. Olympic Fencing Foil Handguard Replacement: step 7, image 1 of 2 Olympic Fencing Foil Handguard Replacement: step 7, image 2 of 2
    • Thread the wire through the new handguard.
    • Insert the new handguard on the foil.
    Ask FixBot
  8. Olympic Fencing Foil Handguard Replacement: step 8, image 1 of 3 Olympic Fencing Foil Handguard Replacement: step 8, image 2 of 3 Olympic Fencing Foil Handguard Replacement: step 8, image 3 of 3
    • Thread the wire through the large sockey holder hole.
    • Insert the sockey holder back onto the foil.
    • Thread the wire through and under the small hole of the socket holder, right next to the sockets.
    Ask FixBot
  9. Olympic Fencing Foil Handguard Replacement: step 9, image 1 of 3 Olympic Fencing Foil Handguard Replacement: step 9, image 2 of 3 Olympic Fencing Foil Handguard Replacement: step 9, image 3 of 3
    • Wrap the exposed part of the wire around the socket.
    • Using a plier to hold the hexnut, use a flathead screwdriver to tighten the socket.
    Ask FixBot
  10. Olympic Fencing Foil Handguard Replacement: step 10, image 1 of 2 Olympic Fencing Foil Handguard Replacement: step 10, image 2 of 2
    • Insert the pad.
    • Insert the grip.
    • When inserting the grip, make sure that the grip is not crushing the wire.
    Ask FixBot
  11. Olympic Fencing Foil Handguard Replacement: step 11, image 1 of 3 Olympic Fencing Foil Handguard Replacement: step 11, image 2 of 3 Olympic Fencing Foil Handguard Replacement: step 11, image 3 of 3
    • Insert and tighten the hexnut.
    Ask FixBot
  12. Olympic Fencing Foil Handguard Replacement: step 12, image 1 of 1
    • Make sure that the foil does not feel loose.
    Ask FixBot
Finish Line
Chuwei Yuan
205 Reputation
1 Guide authored
UC Davis, Team 1-1, Morris Fall 2024 Member of UC Davis, Team 1-1, Morris Fall 2024
UCD-MORRIS-F24S1G1
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 354
