Community-Contributed Guide
Introduction
The Labotronics guide, “How Cross-Contamination Ruins Oil Particle Counts,” explains how unwanted particles introduced during sampling, handling, or testing can affect oil cleanliness measurements.
Oil particle counters measure particles suspended in oil to help assess contamination levels in hydraulic systems, lubrication circuits, and industrial machinery. When foreign particles enter a sample, the reported count may not accurately represent the oil's actual condition, potentially leading to incorrect maintenance decisions.
The article explores common sources of cross-contamination, including unclean sampling containers, contaminated tubing, improper handling, and residue left in testing equipment. These issues can affect particle count results and make it harder to compare measurements over time.
To reduce contamination, laboratories and maintenance teams should clean sampling equipment, use suitable containers, follow consistent sampling procedures, flush testing lines as instructed, and protect samples from external contaminants. Routine equipment checks and proper sample handling also help support meaningful results.
Want to improve oil particle counting accuracy? Read the complete Labotronics guide to learn how cross-contamination affects test results and how proper sampling practices can help reduce errors.
Oil Particle Counter Cross-Contamination Effects on Particle Count Accuracy
0 Guide Comments
