Ohmeda Engström Vent Engine Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Ohmeda Engström Vent Engine Replacement, Vent Engine: step 1, image 1 of 1
    • With the main chassis separated from the cart, position the device upright with the monitor centered to prevent any tipping.
    • Disconnect any external connectors as well as the display connector.
    • Make sure you are working in a clean and dust-free environment to avoid introducing any unwanted debris to the inside of the device.
    Ask FixBot
  2. Ohmeda Engström Vent Engine Replacement: step 2, image 1 of 2 Ohmeda Engström Vent Engine Replacement: step 2, image 2 of 2
    • Push down on the small grey tab below the exhalation valve.
    • While holding the tab down, you should be able to pull and extract the exhalation valve from the device.
    Ask FixBot
  3. Ohmeda Engström Vent Engine Replacement: step 3, image 1 of 1
    • There are four Phillips screws to be removed at each corner of the back of the device.
    • Once the screws are removed, slide the housing along with display to reveal the main chassis.
    Ask FixBot
  4. Ohmeda Engström Vent Engine Replacement: step 4, image 1 of 2 Ohmeda Engström Vent Engine Replacement: step 4, image 2 of 2
    • Remove the circuit board retainer in the upper right by unscrewing the four screws (M4-0.7 x 12mm Phillips) that hold it in place.
    • Disconnect the connectors coming from the vent engine to the circuitry.
    • Avoid any unnecessary contact with circuit board components.
    Ask FixBot
  5. Ohmeda Engström Vent Engine Replacement: step 5, image 1 of 1
    • The vent engine is held in place by two screws on each side of the device. Unscrew all four and remove the vent engine.
    • Install the new vent engine and screw into place.
    • Connect the vent engine connectors to the circuit board and reinstall the circuit board retainer.
    Ask FixBot
Jonathan Honrada
136 Reputation
1 Guide authored
Cal Poly, Team S7-G6, Paton Spring 2020 Member of Cal Poly, Team S7-G6, Paton Spring 2020
CPSU-PATON-S20S7G6
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 456
