Office Chair Caster Wheels Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
34
Past 30 Days:
163
All Time:
1,855
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide covers repairing the caster wheels on an Ikea Malkolm Office Chair Model Number 20196812.
When office chairs are used on carpet flooring, the casters are susceptible to falling out, or they would need to be replaced due to wear and tear. This simple guide will cover removing, cleaning and reattaching the caster wheels using household objects. Some other possible issues are also covered, such as applying a lubricant if the wheels are too stiff or locking the casters in place.
The process will also involve using a sharp-edge tool that could cause injury, so follow the guide with caution to prevent injury.
Tools
    1. Office Chair Caster Wheels Replacement, Caster Wheels: step 1, image 1 of 3 Office Chair Caster Wheels Replacement, Caster Wheels: step 1, image 2 of 3 Office Chair Caster Wheels Replacement, Caster Wheels: step 1, image 3 of 3
      • Turn the chair over to the side to access the caster wheels.
      Ask FixBot
    2. Office Chair Caster Wheels Replacement: step 2, image 1 of 3 Office Chair Caster Wheels Replacement: step 2, image 2 of 3 Office Chair Caster Wheels Replacement: step 2, image 3 of 3
      • Remove the caster wheels from the socket using any flat edge such as a metal spudger.
      • Be careful not to injure yourself while handling sharp objects.
      Ask FixBot
    3. Office Chair Caster Wheels Replacement: step 3, image 1 of 3 Office Chair Caster Wheels Replacement: step 3, image 2 of 3 Office Chair Caster Wheels Replacement: step 3, image 3 of 3
      • Wipe off the caster wheel bracket.
      • Optional: If you are having trouble spinning the wheels, apply a lubricant such as WD40.
      Ask FixBot
    4. Office Chair Caster Wheels Replacement: step 4, image 1 of 3 Office Chair Caster Wheels Replacement: step 4, image 2 of 3 Office Chair Caster Wheels Replacement: step 4, image 3 of 3
      • Get a firm grip on the caster wheels and put enough pressure to reinsert the caster back inside the socket.
      • Optional: If you are struggling to reinsert the caster, then try using a mallet or hammer to lock the wheels in place.
      Ask FixBot
    5. Office Chair Caster Wheels Replacement: step 5, image 1 of 3 Office Chair Caster Wheels Replacement: step 5, image 2 of 3 Office Chair Caster Wheels Replacement: step 5, image 3 of 3
      • Check to ensure that the wheels are secure.
      • We recommend lifting the chair or tilting it on each side to check for any loose wheels that could fall out.
      Ask FixBot
    6. Office Chair Caster Wheels Replacement: step 6, image 1 of 3 Office Chair Caster Wheels Replacement: step 6, image 2 of 3 Office Chair Caster Wheels Replacement: step 6, image 3 of 3
      • Have a seat and test the movement functionality.
      • Ask yourself if the chair is moving properly and are the wheels secure.
      • If the answer is yes, then congratulations! Your repair was successful! If not, try some of the optional points covered in the previous steps.
      Ask FixBot
Finish Line
Ivan
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 163
All Time: 1,855
