Up to 20% off select tools
Oculus Touch Controllers (2nd generation) Battery Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
70
All Time:
2,404
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 seconds - 1 minute
Difficulty: Very easy
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
In this guide, you will be learned how to swap out your Oculus Touch batteries if you give your headset to a friend and someone else, you do need to know how to replace batteries, if you want to continue playing, You only need an Opening tool and that’s all!
    1. Oculus Touch Controllers (2nd generation) Battery Replacement, Opening: step 1, image 1 of 1
      • Slide down the cover on the left or right side of your chosen controller.
      Ask FixBot
    2. Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: step 2, image 1 of 3 Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: step 2, image 2 of 3 Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: step 2, image 3 of 3
      • After opening, push forward the battery and lift it up while holding the ring on the controller with your other hand.
      • You can also use the top of the cover to push and lift the battery if you don't have an opening tool.
      • Recycle batteries properly.
      Ask FixBot
Author
with
Artem Ivat
4,035 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 70
All Time: 2,404
