Up to 20% off select tools
Oculus Rift Development Kit 2 Lens Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
92
All Time:
2,336
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If there are visible scuffs or scratches in the lenses, they may need to be replaced. However, before buying new replacement lenses, be sure to give the current lenses an obligatory wipe down with a cleaning rag. Often times dust and dirt collects on the lenses and makes them appear blurry.
    1. Oculus Rift Development Kit 2 Lens Replacement, Remove Lens: step 1, image 1 of 2 Oculus Rift Development Kit 2 Lens Replacement, Remove Lens: step 1, image 2 of 2
      • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
      Ask FixBot
Author
with
Adam
661 Reputation
4 Guides authored
Cal Poly, Team 18-5, Maness Winter 2015 Member of Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 92
All Time: 2,336
