Up to 20% off select tools
Oculus Rift Development Kit 2 Display Screen Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
109
All Time:
3,629
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If there are cracks or mars in the video display, the display screen may be broken.
    1. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: step 1, image 1 of 3 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: step 1, image 2 of 3 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: step 1, image 3 of 3
      • Remove front cover plate.
      • Unplug the USB and HDMI cables from the Oculus Rift DK2.
      Ask FixBot
    2. Oculus Rift Development Kit 2 Display Screen Replacement: step 2, image 1 of 3 Oculus Rift Development Kit 2 Display Screen Replacement: step 2, image 2 of 3 Oculus Rift Development Kit 2 Display Screen Replacement: step 2, image 3 of 3
      • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
      Ask FixBot
    3. Oculus Rift Development Kit 2 Display Screen Replacement: step 3, image 1 of 2 Oculus Rift Development Kit 2 Display Screen Replacement: step 3, image 2 of 2
      • With the screws removed, gently pull the headband frame apart from the headset.
      Ask FixBot
    1. Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: step 4, image 1 of 2 Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: step 4, image 2 of 2
      • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
      Ask FixBot
    1. Oculus Rift Development Kit 2 Display Screen Replacement, Headset Motherboard: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
      Ask FixBot
    2. Oculus Rift Development Kit 2 Display Screen Replacement: step 6, image 1 of 1
      • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
      • Read the next step before removing the faceplate!
      Ask FixBot
    3. Oculus Rift Development Kit 2 Display Screen Replacement: step 7, image 1 of 2 Oculus Rift Development Kit 2 Display Screen Replacement: step 7, image 2 of 2
      • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
      • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
      Ask FixBot
    4. Oculus Rift Development Kit 2 Display Screen Replacement: step 8, image 1 of 2 Oculus Rift Development Kit 2 Display Screen Replacement: step 8, image 2 of 2
      • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
      • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
      • The headset should now be two separate pieces.
      Ask FixBot
    5. Oculus Rift Development Kit 2 Display Screen Replacement: step 9, image 1 of 3 Oculus Rift Development Kit 2 Display Screen Replacement: step 9, image 2 of 3 Oculus Rift Development Kit 2 Display Screen Replacement: step 9, image 3 of 3
      • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
      Ask FixBot
    6. Oculus Rift Development Kit 2 Display Screen Replacement: step 10, image 1 of 1
      • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
      Ask FixBot
    7. Oculus Rift Development Kit 2 Display Screen Replacement: step 11, image 1 of 3 Oculus Rift Development Kit 2 Display Screen Replacement: step 11, image 2 of 3 Oculus Rift Development Kit 2 Display Screen Replacement: step 11, image 3 of 3
      • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
      Ask FixBot
    1. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: step 12, image 1 of 3 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: step 12, image 2 of 3 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: step 12, image 3 of 3
      • Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
      • Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
      Ask FixBot
4 other people completed this guide.
Author
with
Adam
661 Reputation
4 Guides authored
Cal Poly, Team 18-5, Maness Winter 2015 Member of Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Members
72 Guides authored
2 Guide Comments
It's possible to use the Samsung Galaxy Note 4 screen?
Lauro Adriano Freitas - Reply Share
moldovancasyan19 - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 109
All Time: 3,629
