Up to 20% off select tools
Oculus Rift Development Kit 2 Cable Hub Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
101
All Time:
3,141
Comments: 4
4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If a cable that connects to the device via the cable hub has become frayed or damaged, the cable hub will need to be replaced in order to replace the damaged cable. This, along with damage to the cable hub itself, will cause the device to malfunction.
    1. Oculus Rift Development Kit 2 Cable Hub Replacement, Cable Hub: step 1, image 1 of 1
      • Using the plastic opening tools, pry open the cable hub.
      Ask FixBot
    2. Oculus Rift Development Kit 2 Cable Hub Replacement: step 2, image 1 of 1
      • Carefully pry the cable away from the cable hub motherboard. It is attached with hot glue and should be removed easily.
      • Note that the cable is soldered on to the board. When prying the cable away from the hot glue, pull gently so as not to damage the soldered wire.
      Ask FixBot
    3. Oculus Rift Development Kit 2 Cable Hub Replacement: step 3, image 1 of 1
      • Desolder the wires as illustrated. This can be done by heating up the solder connecting the board and the wire. When the solder is liquified, pull the wire away from the board.
      • Need some help? Follow this guide to learn soldering basics.
      Ask FixBot
5 other people completed this guide.
Author
with
Alexandra Zaragoza
331 Reputation
1 Guide authored
Cal Poly, Team 18-5, Maness Winter 2015 Member of Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Members
72 Guides authored
4 Guide Comments
Buena guia, faltaria poder ver donde va soldado cada cable, he llevado mi cable a reparar y me lo han devuelto peor de lo que estaba, veo que han usado un cable de 4 hilos mas masa pero el original es de 5 hilos mas masa.
podria decirme donde van soldados los cables por la parte que va de la caja al usb ? ( el tramo corto )
Gracias
Hipolito Rodriguez - Reply Share
Hipolito, pudíste arreglar el problema?
Yo tengo un DK2 que compré usado y vino sin la caja conectora del sensor. Hay forma de fabricar alguna? Reemeplazarla por alguna otra cosa?
Desde ya gracias.
Lea ndro - Reply Share
Puedes conectar directamente el cable del sensor a las gafas, levantas la Tapita de goma que tiene y ahí lo conectas, con un alargador funciona correctamente también
My wires has a short in them where can i purchase a new one?
Ashley - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 101
All Time: 3,141
